I have the opportunity to pick up this light. It is described as a functioning aircraft beacon. One photo looks like it may be missing a bulb as I see an empty socket. Anyone recognize this light and what it may be worth in working condition. Thanks for any help.
This is a Grimes aircraft beacon made to fit a hole in the body of a plane. Beware of voltage, may or may not be 12 Volt. As cmb56 says, there was an automotive version called the Hi-Flash. This is not it. Yes, there is a bulb missing.
These older rotating beacons would fit flush on the top and or bottom of the fuselage, and often in a receptacle on top of the vertical stabilizer. Typically 24V/28V. The development of strobes, and now LED's, superseded these rotating/oscillating beacons, just like on vehicles.
Many older generation general aircraft have updated their lighting to newer and more reliable technology, but every now and then you see one of these REAL beacons.
Thanks everyone for the info. I spoke with the seller. He says its a 12 volt system he took out of an airplane 15 years ago. He is going to try to find a bulb for the one that is missing and get back to me. We'll see what happens.
