Another Holy grail captured - Grimes Ful-View
tsquale
Oct 12, 2010
10,537
Minnesota, USA
This finally arrived today! A Grimes Ful-View and another light to check off the list. Glass is 100% intact. I'll be trading my glass to a member local to me that has one with cracked glass on his 68 Cadillac M&M ambulance. I'll be able to hide the crack while on display and his Ambulance is MINT, so it really needs the nice glass.
IMG_20171115_113931607.jpg IMG_20171115_113910160.jpg IMG_20171115_113921278.jpg
Jun 18, 2013
3,718
PA
Neat,
does this thing spin? Blink?
cmb56
746
Norrköping, Sweden
Are those the same bulbs that are in the old Dietz rotators, that nobody can seem to find anymore?
No, these are special bulbs (Grimes A-7079B-12 14V 40W) for aircraft anti collision lights, because this light is basically a such, and they are still available but expensive.
It is a bulb where half the glass globe is coated to be working as a reflector.
Michael
Reactions: stlfireman
cmb56
746
Norrköping, Sweden
Nice catch.
You seems to have got a rear left light because it do not have a name tag or a front right one.
But my guess is a rear left one.
You can check the casting number to try to see what it is but it seems to have been some different castings depending on of what ambulance they where used on (different sloops of the roofs).
I have a rear right one but with a name tag (added by John Dorgan when he restored the light for me).
Unfortunatly the plastic motor bracket broke in two pieces when shipped to me so I need to get one new or maybe make a new one in a 3D-printer.
Michael
Reactions: jph2
cmb56
746
Norrköping, Sweden
Here are some information I have picked up on some forums.
Miller-Meteor 360 Ful-Vu-Lite.
The front lights where the only ones with the name tags but Grimes also delivered front lights without the name tags.
1969 Miller-Meteor 48" Classic casting numbers:
350-655224 - Right Front
350-655225 - Left Front
350-655226 - Left Rear
350-655227 - Right Rear
Other casting numbers:
350-645226
350-645227
1967 Miller-Meteor casting numbers:
Right hand side - 350-655220
Left hand side - 350-655221
Some other casting numbers:
Front Right: 350-715252
Front Left: 350-715253
Rear Right: 350-715250
Rear Left: 350-715251
Lid casting number:
350-645225
Bulb:
Grimes A-7079B-12
14V 40W
Motor:
Badder-Brown, Model-D305 H65 12VDC 1.8A
Michael
Reactions: jph2
cmb56
746
Norrköping, Sweden
Michael, try Loctite Plastics Bonding System...I've used it on several projects with excellent results.
Ed
Thanks, I might try that sometime.
I have had that as a though but have not tried it because if it fail I have messed the bracket up.
I have had this light for about 10 years and I have not take any time to try any repair yet.
We will see when I feel it is time.
Michael
cmb56
746
Norrköping, Sweden
I have made a correction of the light’s name in my reply made earlier.
I did not remember the light’s exact name when I wrote it but I have now looked at the name tag and it is in fact:
Why it is sometime called Grimes is because it was made by the aviation equipment manufacturer Grimes, now part of Honeywell, from an anti collision light (might have been for a B-52).
The Miller-Meteor plant was nearby the Grimes factory and they made these lights more or less exclusively for Miller-Meteor.
But a few other users have used the lights also. A local fire apparatus manufacturer as it seems.
Someone has a set that came off a Superior Criterion ambulance.
If that was an aftermarket installation (old M-M lights) or a factory installation (special order), I do not know but I can not recall I ever have seen a Superior ambulance with these lights.
Michael
idk
