Best Ford Explorer POV! NEW DUAL COLOR SCENE LIGHTS TODAY!
JCS
37
Iowa
I, too, have recently been moving more toward a LAW in the turn signal rather than the normal HL area.
You isolate the reflection to that area, its usually smaller (we use F250/350's) so ours is large, but you don't have it washed out nearly as bad as if it were in the HL reflector. They are far more effective IMO.
JohnFireFan
323
Louisiana
Well I will go ahead and put a big "X" over the LAW idea.
Any heads up on the latest and or upcoming products from Feniex Industries? I would like to see dual color Cobras with 3 modes like the Cannons!
Carlos SpicyWeiner
May 3, 2012
5,233
Lakeland, Florida
Last i heard, there is no plans to tinker with the Cobras as they are.  They will stay single color.
JohnFireFan
323
Louisiana
I did an install for a fire chief with a new Taurus, same style grille. A t6 fits perfect in the slat right above or below the center line of the grille. I used 3M auto grade mounting tape to hold it. They are flush mount to the face. Blend in nice. Will try and get pic
How did you mount the Feniex T-6s with 3M auto tape? Did you put one piece on the top and bottom of the T-6 or did you just tape it to the back of the light and onto the grill?
Kd8bao
793
Independence, Ohio
Just on the top. No bezel. It was a snug fit so it holds good. The face is flush with the grille face. I have to get a pic from the guy
acala91
1,662
FL
I would change the pattern on the rear stick. I don't like those patterns because they aren't very noticeable from a distance. A half and half pattern is what I would choose.
I still think it needs additional lighting to the front. Maybe some Whelen fog light inserts or something like an Ion in the grill. Also, one of the ERM HLF would look good if it is legal for him to run one.
Otherwise everything else looks good.
Reactions: sean_quish
pdk9
3,834
New York & Florida
1) flash the rear lightstick so that you're alternating the outer 4 modules with the 2 inner modules (at a wigwag speed)
2) add solid red grill lights (your original plan called for split R/C) and HLF
3) add intersectors and call it a day
It's a nice explorer, but it just needs a few additions
pdk9
3,834
New York & Florida
I know it's a PITA to remove the grill, but would you consider moving the grill lights higher up? Putting them in one of the 2 slats above the ford logo would be ideal, IMHO, & appear to be the same size spaces as the one where you currently have them mounted
nathanzx10r
182
Odessa, TX
Or adding 2 more in the spot pdk9 was saying and keeping the ones you have there in place and sync
Reactions: FusionWolf
JohnFireFan
323
Louisiana
The spot you mentioned was my original plan but for some reason the slots above the Ford logo has a piece of black plastic covering the back of the slots up. I could have simply drilled a hole through it and ran the wires but I just opted to mount them lower instead. I might consider adding a set of Feniex T-6s to the top but as of right now I have already had plenty of one on one time with removing the front bumper. LOL.
Video will come shortly of the lights. Please bare with me.
Thanks for all the criticism and ideas. This was originally the finished product I had hoped for and do not have any more plans of adding lights although I might consider buying another siren amplifier instead of the Carson 1022 I currently have.
Here is the video with the added grill lights and intersection lights.
http://youtu.be/WS5x6aRs6uQ - Daytime video of lights
http://youtu.be/Po_6-_iJHmI - Nighttime video of lights
pdk9
3,834
New York & Florida
I would triple flash the 2 grill lights together and add a HLF, as mentioned above. I would Flash the two red grill lights simultaneously, because HLFs IMO tend to wash out the grill lights at night unless they're flashing together.
Some simple adjustments I'd recommend are:
--Flipping over the passenger side cobra, so that both headliner lights have the clear modules toward the center (as TDs would be on a full size bar) & triple flash the headliner lights by alternating red with white
--my 2 suggestions from above (HLF and changing the rear lightstick pattern)
PS, I found it funny that you blurred out the front license plate in the video, yet there are a dozen close up pictures of the license plate in the grill assembly/lighting installation pics lol
nathanzx10r
182
Odessa, TX
What pattern would you suggest? I currently have it on the Double Combo but might consider the Single Fast flash pattern for the front grill lights.
Experiment, see what flash patterns look the best for your setup and provide the most warning power.  I would keep the reds and the whites in the grills flashing the same color at the same time as to not make ya pink at longer distances.
JohnFireFan
323
Louisiana
I might take in consideration some of the ideas you gave. I only did that in the video for other YouTubers. I don't mind showing it off to the ELB members :p
Eric1249
2,277
Waukesha WI USA
With a headlight flasher I would set the grille lights to a triple or quad flash so there more on time.  Then the HLF won't wash out the grille lights so much.
JohnFireFan
323
Louisiana
Since the Explorer is all Feniex I hate to install Whelen lights on it but I really want flashing fog lights.
Which color warning fog lights looks better? Red or White
Whelen 3.5" Round Super LED Lighthead
PART NUMBERS:
PAR28C = All White
PAR28DR = Red/White Fog *This color combination does not have the SYNC feature. External flasher is required in order for lights to SYNC.
An external flasher is required for both units in order to achieve the purpose I want. Purpose 1: Fog Lights, Purpose 2: SYNC'd Warning Lights
Mar 25, 2014
91
Saint Louis, MO
PART NUMBERS:
PAR28C = All White
I would use the PAR28DR. I replaced my factory fog lights with the PAR28DB in my Charger. Then set the warning mode to steady burn and used a Sho-Me 11.1005 flasher I had laying around. When I completed the install I was suprised to find out that if I had my fog lights on, it would flash both of the white fog light and the blue warning light. And if I didn't want the fog lights to flash with the blue lights I just turned off the fog lights using the factory switch. I hope that makes since, if not I will make a youtube video and add a link.
JohnFireFan
323
Louisiana
A video would be great!
buddek09
339
US, Ohio
If you want to stick with Feniex, why not stick use dual color cannons for replace the fog lights? It would be about the same price of the Whelen's, it might require a bit more work and some assembly. I added the cannons to the fog light area of the local pd's vehicles that I did this year and everyone loves them because it looks like it was a factory option.
91
Saint Louis, MO
That's what I did originally in my vehicle but it didn't, IMO, put out as much light.
Eric1249
2,277
Waukesha WI USA
I am a big Feniex fan but if I could use Whelen PAR's as my fogs/warning or Cannons I would go with the PAR's. I had them in my old Explorer. Great lights. I had white for fogs and all red for warning. They were ran to a ULF44.
GSPS629
