Cencom Sapphire Bench Test Setup
lightsNsounds
12
IL
Dear forum members,
I am in the process of constructing a benchtop station to test the functionality of the cencom Sapphire before install, but I am experiencing some problems.. I will try to be as descriptive as possible:
1) connected the main 100amp power harness to a 12v power supply
2) jumped the ignition wire to turn the cencom on
3) connected the controller to the ethernet port
The problem Im having is that the controller isn't powering up.. is there something Im missing?
P.S. the cencom and controller have both been tested to verify their functionality in a vehicle.
fleetcomm
717
south of nowhere
Try hooking it up to a battery instead of a power supply.
lightsNsounds
12
IL
EMT-BLS said:
You need to connect Pin 14 (ignition) to power.
I'm sorry if my description was confusing, but that was my second step.. the Pwr light on the back of the cencom is on, so I know the cencom is receiving power.. but thanks for the help, that pin14 is something that is often missed =]
EMT-BLS
2,640
Waterbury, CT
So what exactly happens? You plug the two reds to power, two black to ground, and Pin 14 to power (continuous). What does the system do?
lightsNsounds
12
IL
Specifically, I need to verify the functionality of outputs: 4,5,6, & 7. As long as I can get the LEDs on the top of the cencom to light up, I know I'm in business.
lightsNsounds
12
IL
I get nothing. Typically when you turn the controller on or inbetween functionalities it makes a beeping sound, I dont even get that. I called whelen and they said that it had something to do with the cencom looking for a whelen lightbar. Which kinda makes sense since the WC light blinks on the rear of the cencom. I just don't know how to go about tricking the cencom if that in fact is the problem
fleetcomm
717
south of nowhere
That does not make sense because I am using the sapphire on my new vehicles and I do not have a wc lightbar hooked to it.
lightsNsounds
12
IL
I knew the guy was blowing smoke, but figured I'd post it up anywayz
Keith K.
Western States
On page 4 of the instillation manual.
Step 4 - "IMPORTANT: The CenCom module case must be either mounted on, or grounded to the vehicle chassis."
I can't say for sure, but maybe this is the problem?
fleetcomm
717
south of nowhere
I just bench tested a new cen com sapphire unit and it does not need the case grounded. My unit workes fine on the bench hooked to a power supply and here is a crude set up just to show you. DSC02443.jpg
lightsNsounds
12
IL
fleetcomm said:
I just bench tested a new cen com sapphire unit and it does not need the case grounded. My unit workes fine on the bench hooked to a power supply and here is a crude set up just to show you. View attachment 46524
Perfect! So it does not require the lightbar to be connected (as was our assumption). But just out of curiosity, does the unit function without all the other connectors and simply jumping a wire from the main pwr harness to the remote pin? It seems like you have the perfect setup for a quick check :undecided:
aacosta367
116
North Jersery
This might help you, but run through check ist
1. check for a good ground.
2. Also check your power not with a test light but with a Voltage checker
3. Make your using correct wire gauge for the unit power supply
pm me any question have that unit install in my truck
lightsNsounds
12
IL
The unit doesn't necessarily need to be grounded (as proven by fleetcomm)
All measurements are taken by a multimeter
Wiring gauges have been verified.
All great points though.. I really appreciate any help/insight on this matter, no matter how small. Seeing as how the simplest mistakes are often overlooked.
fleetcomm
717
south of nowhere
the wires I have hooked up are the (14) red/black wire, the (7) white/black, the two 50 amp red and the two ground wires. I would also check the programing to make sure load management has not been set for a voltage higher than you are working with.
lightsNsounds
12
IL
Pin 7 (backlight imput)? That's gotta be it! I shall try it when I return to work tomorrow and let you know.
lightsNsounds
12
IL
I went ahead and hooked up pin14 and no change :mad:
I was wrong earlier in my description of the diagnostic LEDs,
Pwr = solid
Wc = off
Err = blinking 3 times (which isnt in the manual)
Im starting to get frustrated with what should have been a simple project
Keith K.
Western States
You stated that both the amp and head checked ok on a vehicle. Is your power supply providing adequate voltage? What is the rated output in amps for continuous duty?
lightsNsounds
12
IL
Correct. Both check out..
Actual voltage: 12.6v
Rated at 5Ah
Keith K.
Western States
Rated at 5Ah
Is the head to amp cable damaged?
If you have everything hooked up in the manner that has been described above and both parts work in a vehicle, I'd suspect that there is an issue with your power supply. I've had bench top power supplies fail to provide adequate current, but still provide a good 12v signal. If you have another DC power supply, I'd try bench testing your system on that to rule out a bad power supply.
rwo978
ND, USA
Where does the Glock come into play with bench testing? Mag dump when it doesn't work? :)
fleetcomm
717
south of nowhere
It is the equivalent of a bigger hammer. no, I had just gotten my new 30S glock that day.
California
Did you ever get this working? Just reload the default program... step 2 in troubleshooting a programmable unit of any kind..
Use the latest software..
Who knows what was in there before..
carguy411
372
ny
has anyone figured the problem out. i am going thru the same thing i tried everything and nada.\
the first trouble light is blinking saying check wecan lightbar
now i am goetting a wecan lightbar but it isnt in yet the liberty is on backorder so i wanted to try everything else to make sure im good and i can even do that. is there a way of turing offf the wecan controller in the system so i can use it as a normal unit? i looked in programming found nothing unless im over looking it??
please help thanks
California
please help thanks
There should be no reason it is not working... the error light will not make the rest of the unit not function - so it is something else - by default the unit shows up with a program that includes a bar.. if no bar is attached it will error but all other outputs should work.
Is the unit new?
What is hooked up to what?
Have photos?
Are the power and main large gauge output wires attached to the correct connectors? Many people mix these up and the unit will not work - best way to tell is two LED's will be lit on the ARM, but nothing will work.
SHOF
98
IN
IMO it has to be a wiring issue. Check all wire connections. Then double check. Then triple check with the manual. I have never had any issues with a Cencom.
carguy411
372
ny
It's brand new out if box. I have 2 8 ga red to 12v red/ black ign to 12v 2 10 ga black to ground even tried grounding case. And have controller plugged in doesn't even lite up or anything. But it takes the program i confirmed that with the timed output feature
carguy411
372
ny
That doesn't work either no buttons work slide switch I get no response from the controller at all.
SHOF
98
IN
Do you have the ignition wire hooked up? I believe it is red/black. It has to have 12v for the unit to work.
carguy411
372
ny
It almost seems like the controlle head isn't responding. But the brain is. I'm stuck Whelen hotline only is open during the week??
roseofblue84
