Changing my Setup 2007 F150
TNFF412N
387
0
San Antonio, Texas
Right now i have
4 Lin4s in red
2 Tir3s in white in the grill
i want to add
2 Tir3s in red
2 Tir3s in white
right now they are all in a row centered in the grill s you can see from the video
I want to spread them out and have an X pattern going on
So it will be 6 reds and 4 whites in the grill
how should i set them up and were
double up or triple up on the lightheads so you have 9 optics in the same lighthead and keep the wigwag on each side of the ford badge. i would keep move the lightheads to the upper grille
move the avenger around the rvm and set it to a single slow flash pattern
you can use the lower grille too
here is some ideas
TNFF412N said:
Right now i have
4 Lin4s in red
i want to add
2 Tir3s in red
2 Tir3s in white
I's mount 2 of each lighthead together so there is a larger footprint (in other words, for the x-pattern you have the 2 red lin4's in the top left flashing simultaneously with the 2 white tir3 in the lower right corner ----> the 2 red lin4 in the top right and the 2 white tir3 in the bottom left of the grill will flash ). i'd stack them in pairs so that there is a bigger punch/footprint (i personally don't think the small tir3's in a truck grill don't look that good on their own unless they're stacked or, ideally, they're replaced with something like a pair of tir6's). i would space them out and do something like this:
Red Lin4--------------------------------Red Lin4
-------------------(Ford Logo)---------------------
White tir3------------------------------White tir3
i'd then take the 2 spare tir3 and put them on a 10-75 bracket
That would look good I think. Make a bigger chunk of light flash at the same time.
AnotherMike
