Code 3 Model 420 with D-Tech Rotators???
lotsofbars
1,999
NYC, New York
Out of all the terrible ideas . . .
But really, it's been done but D-Tech rotators suck at throwing light, so they're generally just a really fast twinkly blur. I wouldn't recommend it.
chief1562
5,840
Slaterville/NY
shues said:
I'm not sure if this was a retrofit or a factory job:
I just looked at the 2012-2013 parts list and the d-tech was not an option or a replacement part.
tvsjr
611
TX
D-Tech sucks. End of story. They are two fast, twinkly, and they will end up orange and teal after some period of time.
Apr 28, 2012
1,042
Knox County, ME
i want one.... seriously ........
shues
NW Indiana
The second-generation glass D-Techs are far superior, at least as far as resistance to changing color.
tvsjr
611
TX
They're still "twinkly" as all hell and not effective. A nearby large SO is a through-and-through C3 department and drank the D-Tech koolaid early. Those MX7Ks were a constant source of problems, with the rotators having to be replaced constantly. Even the second-gen will change colors sitting in the Texas sun in August on a wreck running for hours. The department couldn't get to the 2100s (which suck in their own way, being basically unsynchronized) fast enough.
So... again I say, D-Tech sucks.
Zapp Brannigan
May 23, 2010
3,580
I would think these are only best suited to sit on a wall in a man cave and look pretty.
And I hope to get an MX7K or other bar with them for just that one day!
Firefly Berlin
330
Germany / Berlin
I have two MXs with D Techs sitting on my wall and they are nice to show, but I would not really want to use them for primary warning.
If I would build them in a 420 I would use slow 24 volt motors so they would turn really slow. ;)
shues
NW Indiana
Slow motors and bright bulbs, perhaps like the H5, just might make them worthwhile.
Rhinojoe
83
Exempt
Well if someone has a set I'm looking to retrofit a Mdl 420. Probably going to see if the slower motors will help.
Thanks guys
RJ
Berlin, MI, 48002
They did offer them from the factory in the 420 bars. I've also made one from a 420 shell; pretty much it's just a matter of changing the reflectors.
It's a cool idea (D-Tech) but the reflectors don't really 'reflect' much.
Plus for what those things ended up costing when they were new, 1/2 cylinder filters with normal rotators would have probably been way more effective.
dg0223
703
USA/Texas
I happen to think they look pretty cool, as far as a display piece goes. I have a Code 360 with two D-Techs in the lower bulbous sections. I was looking for a video, but the only video of mine I have is my Code 360 with standard rotators before I switched them out. This video is not mine, but they look pretty cool. I know as far as warning lights they may not have been as effective, but for a collection piece, they look pretty cool.
chief1562
5,840
Slaterville/NY
Here's the pdf on the 2012-2013 code 3 parts catalog ok can't load the PDF to large excedes the 2 limit size. Here's the page for the 420.
Found on page 94
lite-em-up
116
Eastern Missouri
Here's my MX with D-Techs. I use it for fire responses. Contrary to all of the negative comments here, it is very effective. I have all slow motors and often run just the four D-Tech rotators.
Here is my excalibur beacon
This is my factory 420
Zapp Brannigan
May 23, 2010
3,580
lite-em-up said:
Here's my MX with D-Techs. I use it for fire responses. Contrary to all of the negative comments here, it is very effective. I have all slow motors and often run just the four D-Techs rotators.
You are not a brand new member, how DARE you come forth and tell us you have the slow motors and only post pictures and no videos?!?!?!? :duh: :weird: :hopeless: :bonk:
HILO
2,781
Grand Prairie Texas
Funny you brought DSO up! The same day you posted this, I drove past a courtesy patrol truck that still has a D-Tech MX on it.
I've never cared for the D-Tech. The concept was cool, but the application not so much. I have seen them with slower rotators, and it is a bit better. But like any fast flashing light, it blurs the colors. R/B=purple. B/A=green. Lights need a black out time to have an effective flash. Be it rotating, LED, or strobe, fast flashing is not very effective.
Rhinojoe
83
Exempt
Nice LB420DTS and SD Models
The 420 that I just received(manufacture date 12/12) shows the following replacement p/n's;
D-Tech Rotator R/B T02651 A/B T02652
Would I have to add the friction washer to retrofit the T-Techs?
If anyone has the two D-Tech P/Ns in stock please PM with pricing.
Thanks
RJ
Berlin, MI, 48002
The reflectors gears are the same I believe. I think you just pull the snap ring & slide the normal reflectors off. Getting the snap rings back on without removing the d-tech reflector from the gear isn't much fun, but can be done. I don't think any other parts are needed to change over.
shues
NW Indiana
The glass d-tech reflectors come off of the rotator gear with about a quarter turn, to facilitate snap-ring installation and removal.
Berlin, MI, 48002
I've always had problems getting them back on - plastic & glass. They just don't seem secure; but maybe it was me.
The glass seem easier, but the plastic ones usually try to crumble into a glittery mess.
May 23, 2013
458
nc
on a side note
where do you get a mini excalibur bar?
i would give a certian body part for one of those in red
never seen any till ive been on this site, even an amber one would be sufice
Berlin, MI, 48002
tacomabanga19861986 said:
on a side note
You can buy them new:
PSE Excalibur Mini Light Bar | Truck n Tow.com
Myself, I've made a few by ordering a new lower dome & new upper dome (about $100 for both), & cut my own frames. Code 3 Rotators & / or LEDs are pretty inexpensive so you can fill it to the brim & save some $$$ if you put it together yourself. That light has always been one of my favorites.
htamboli
