Cutting down a lightbar frame
May 22, 2010
787
Columbiana County, Ohio
Does anyone have any suggestions whom I need to contact about cutting down a full size lightbar frame ?
I wouldn't think that all welding shops would have the abilities to cut whelen edge frames or mx's and all...
Anyone here in Ohio willing to offer there services for a fee ?
JohnMarcson
May 7, 2010
10,806
Northwest Ohio
I use a cut off miter saw because that's what I had available to me. I know members have taken them to local metal shops and had them cut with bandsaws for a nicer cut.
NJ & IA
Dude my first time cutting a frame I took a K12 circular saw and just cut. It was a little ugly but if you're careful you can do it that way - would suggest it as a last resort method though...
deputychief301
Snow Belt, Michigan
I have used a air hack saw which works good as long as use have a piece of straight metal
you attach to your straight cutting line, if cutting an edge down make sure using the side
with the hole in the bottom for the wiring harness, this saves you from boring another later.
Take your time and make its exactly what you needing.Once cut, there is way of going back.
For the typical mini edge, the actual bar/frame should be 24 inches and after complete the
two end caps make up two inches on end, making it a 28 inch mini edge, for gods sake if you
use magnet ,use at least 6-95 magnet. I use 8-95lb , so the bar is going anywhere for sure.
If you need any help, get ahold of
Jim Rogers
deputychief301
charlesglass2002
