D4 Headliner Mounting
dwg1523
71
North Florida
Any ideas on the best way to mount a D4 inside the rear of my cab on a 2003 F-150? I have the swivel bracket from whelen to work with. I have tried to visualize it before ripping it apart, nothing seems to pop into my head. Any and all ideas will be greatly appreciated. Thanks!
welcome to ELB.
how far apart from each other are the screws holding up the headliner in the rear of your cab? i mounted a dominator 6 in the rear of my Highlander to the headliner with l-brackets from lowes and self-tapping screws (replacing the plastic screws that hold the headliner up, so that i didn't have to drill extra holes in the headliner)
I have installed several D4/D6's by using the DBKT3 Swivel Brackets. Very easy to mount to the vehicle's rear plastic headliner. Only need to make two small holes for the screws and snap the plastic headliner back up and you are done. I have used this technique for mounting D4/D6's in many vehicles and all of them have not moved at all in years. The red push-button in the photo below is for changing the Dominator flash pattern. The DBKT4 "L" Brackets also will work on most SUV's and trucks.
Thanks for the great ideas guys! I will hoepfully be installing it today after work. I will be sure to put pics up when its finished.
Jackisback
