Dietz 240-1-WW "Hill Light"
gtpts27
579
Virginia
Unknowingly picked up a rare Dietz hill light. 240-1-WW. -1 signifies bar mount (has a full metal bottom vs just an edge for roof stripping). -WW (wig-wag aka hill liggt) signifies one bulb holder has a 10deg upward focus and other holder a 10deg downward focus. Weird to have juat a two-bulb hill light so I assume this was designed to be mounted on a crossbar paired with a standard 240-1 to provide full level and hill coverage.
Originally thought the bulb holders were bent but thanks to @cmb56 for help identifying this wasn't the case and for below literature pic. Thanks to @lotsofbars for help too. Now to try to find a correct clear dome (iso post made in wanted parts forum).
stansdds
3,540
U.S.A., Virginia
Interesting and unusual. The two-bulb hill lights are not particularly common items, those designed for mounting on a bar, even less common. Federal Signal had a hill version of their Model 14 too, it had one bulb mounted level, the other tilted up 10 degrees. These too are rarely seen items.
toon80
2,489
Laval, Canada
Speaking of 2 beams hill lights, I have one that was made by Dominion Auto, as far as I can tell, for the Toronto airport police to be seen by aircrafts while on the tarmac.
2 beams only, both tilted upward.
I'll dig up pics later.
bpollard
425
USA, SC
I seem to recall reading a brochure about this type of light being designed for airport use also. the upward beam was for cockpit visibility while taxiing etc. the downward angled beam would create a circular beam of light on the ground around the vehicle that could be seen from the air. supposedly
CrownVic97
Hazen, ND
When I first got my Tripp Lite S-75 "hill" beacon, it had both par36 bulbs tilted upward while the par46 bulbs were on the horizontal plane. Definitely used at an airport before I got it and returned it back to the original configuration.
RetLt2020
