Edge mounting feet & Freedom module amp draw question
grfd711
1,546
Sherwood, AR
Getting closer to completing this project at work. Here's the issue: I have two custom cut mini bars. A set of feet will not slide completely in them, but it's enough that each mounting foot slides in where the screws tighten down. Considering we'll be mounting the feet directly to the cab of the rig, we don't have a need for the metal plate that a bolt would slide into on the Edge feet for clamps to hook to.
So, has anybody mounted an Edge with part of the feet sticking out from each side with any ill effects? I'm thinking the part of the foot that has the screws that screw into the bottom of the frame will be enough to hold.
Also, does anybody know in amps and watts how much a Freedom and/or 6over6 400 series module draws? Gonna be hooking some up to a ULF44 and want to know how many I can run off of each lead.
Well according to Whelens lighthead guide , The 500 series draws 900ma I would imagine that you would double that for a split . If I recall correctly The ULF 44 is 5 amps per channel max. hope this helps, Ray.
I have a mini edge mounted on the top of one of my box vans using self tapping screws through the holes in the feet and it has been there for four years with no problems. One of my employees even hit a bunch of branches on a tree one day and only broke a lense. The lightbar didn't move an inch.
We did some custom cutting to the Edge feet to get both to fit underneath the frame. The feet we're using is the six holed feet, so, four will have rubber pads and the other two will mount into the cab of the engine. Just gotta wait for the other two feet to arrive for the other mini-bar.
T.Simmons
