Edge Series Bolts
WhelenNDealin
Site Regular
What are the diameter, length and thread for the Torx screws used on the Edge series of lights?
Sparky_911
I cant tell you dimensions or thread pitch but If you are referring to the end cap bolts they are called shoulder bolts.
From my experience they use the same bolts all the way back to edge and up to freedoms and liberty/Patriot series of bars. I'll see if I can get some measurements after work.
SMGUSER
They are shoulder bolts. The OD of the thread is about .182 with a 24 TPI pitch (A 10-24 nut screwed into the threads with no problem.). The length of the threaded part is .945 inches, including a starting area on the leading part which is not threaded. The starting part is about .250 inches long with a diameter of .145 inches. The shoulder is about .290 inches long from the underside of the bolt head to where the threads start and about .247 inches in diameter. The overall length is about 1.350 inches. It uses a T-25 Torx bit to remove them. This bolt is from a Freedom bar.
OP
OP
WhelenNDealin
WhelenNDealin
Site Regular
Holy crap that's some good detail! Thank you!! The guys at the fastener place will see this and not only will it make their job easier but they're likely going to say the same about the details. Much better than going in with one and getting what their best guess is! Awesome stuff!
Pete L.
Site Veteran
The shouldered bolt was for the later Edge, 9M, freedom etc.
The early Edge 9000 bars used a non-shouldered bolt of the same dimensions.
Nolines
Silver Supporter
If I remember correctly they did change those dimensions after a while didn't they cause I was asked about that through one of my suppliers when I was replacing end caps.
SMGUSER
Pretty sure the shoulders prevent over-tightening of the bolts and breaking the endcaps.
How many of these bolts do you need? I'm sure someone has extras. I might even have a few. I don't think they are something you could get at a hardware store.
OP
OP
WhelenNDealin
WhelenNDealin
Site Regular
I need a full set of 8. I was going to look at the three places here that specialize in fasteners (Brafasco, Rastall and Fastenal) . They're national chains. I've had pretty good luck with them getting assorted screws and bolts for various different things. I got the screws for a refurb of a couple Whelen Pioneers and my twin.
OP
OP
WhelenNDealin
WhelenNDealin
Site Regular
Thanks! I'm pretty hopeful thanks to the info that you and Sparky_911, Pete L and nolines' provided. Throw in the fact that I've gotten ahold of some pretty specific fasteners from Fastenal and l think that I'll be good to go. I'll start with Rastall as it's right around the corner and then try the other two. They're also within walking distance and on the same block to boot!
Online statistics
Members online
7
Guests online
125
Total visitors
132
Forum statistics
jasonmen07
Secure Browsing
Top Bottom
