theroofable
theroofable said:I will let the pics do the talking...
theroofable said:The light was just flashing as it has done for the past 7 years of being in service. There is no damage to the wires or the plug. Someone noticed the smell of something burning, walked over and saw the smoke pouring from the light as the lens was melting. The malfunction had to be within the light itself, starting from the corner where it is melted the most.
This is a Whelen 600 series 5mm style led. I hope the rest of them do not do the same thing.
chief1565 said:Well than that is a major failure.
dmathieu said:I'd bring Whelen in on this!
Lucky it was caught!
theroofable said:I agree!
Yes, it was mounted on aluminum, so it didn't damage any paint or anything. I want to send it back to them, but it smells so bad that I will have to let it air out for a at least a few weeks. That way the post office doesn't think its a suspicious package or anything.
It did smell so strongly that when you walked in the firehouse, you could smell it, and it was outside.
LED said:I've never seen a 5mm LED lighthead with that type of damage, almost no heat at all from those bad boys.
bluestinger90 said:How reliable is the trucks electrical system? If the trucks electrical system gave too high a consistent voltage, or caused a massive spike in voltage, it would probably overheat the resistors embedded in the black epoxy and eventually cause a fire.
JohnMarcson said:Looks like a failure of some electronic component within the potted material. This is the first one I have ever seen fail this way. I'm sure a Whelen rep has seen this by now... but I'd be interested what they tell you directly.
Strobesnmore said:What were the lights fused at because seems like the fuse should have popped.
theroofable said:I would like a comment from them. It is not a major deal to replace this, just more concerned that it could have been much worse.
I am going to check on what kind of circuit protection is in place, but regardless, something internally must have gone wrong to short in the first place. What ever the protection on the circuit is, was done by the manufacturer when it was built in 2006.
JohnMarcson said:Breakers trip because of overload or short. It is possible that this had yet to cause either condition to the extent that the breaker is rated. Within a LED head you are dealing with multiple electrical components working at different voltages and amperage than the 12v system that supplies it. Internal failure of components do not always trip the 12v 30A breaker at the supply side of the wiring. This is however the first major internal thermal event I have seen in a product of this type. I have seen Chinese TIR lights melt-out or burn up and a perfectly good breaker never tripped.
Zapp Brannigan said:Well this is certainly not what I expected to see...
From the title I was expecting to see an ETD failure!! :crazy:
theroofable said:I was thinking along the same lines. This light probably draws around 1a when running normally. Im thinking though it would have drawn a bit more when on fire though.
Associated with my name? I think not!
Strobesnmore said:I'm am still leaning towards something wrong with the wiring. To burn that hot to cook the potting will take some amperage and the fuse should have blown.
