dmathieu
Captain4164 said:I plan on using the "O", just havent got around to mounting it yet, then dealing with the wiring and how I wanna do the activation switch. For now, the light is done and ready to go. Gotta get working on the pick up bed body work, and Ill talk to a buddy of mine thats pretty much an electrical guru, and see if he can come up with something authentic for the siren.
fyrboy said:Obviously I came to this party late, not to mention uninvited. The item pictured below is a JBR base. Please let me know if it can it be of use in this issue.
How much?
Captain4164 said:Ha ha ha ha, easy Skip, Im not made of money, contrary to what the unemployed wife thinks.
Captain4164 said:Well I picked up the Jr skirt from the chrome shop today, along with a bunch of other stuff I had done for the truck, all interior stuff, and the Q body cover. I also dropped off the 77G stator and face plate, cant wait to see that cuz its so beat up, and he said it will be no problem to get it smooth.
Anyway, heres the chrome stuff I had done
Captain4164 said:Thanks Dan, IM happy with it.
Isnt there someone on here that restores the badges? This one almost doesnt look right on it anymore
dmathieu said:I think his name is fyrboy.
Captain4164 said:Thanks. Then to find a 6v motor, got a post in the want ads. Really would like this to spin a little faster
Captain4164 said:I think they will be ok, the roof of the Power Wagon is so high that you really cant even see the base of the Jr, unless you get up on the running boards, and plus this gives me a way to get my fingers under it to take it off.
Skip Goulet said:Handn't thought about the removal aspect, Nick! But the one pictured looks like the magnets make the light lean to one side a bit. I had a single big magnet on a junior years ago which worked fine. But now it's one of the juniors mounted on my '74 van ambulance....permanently.
Captain4164 said:Nah, thats cuz it was sitting on the wire, and on an angle on the hod of my Dakota
Hoser said:Please keep us posted on your progress with the Power Wagon. Had a 78 Power wagon Snow Commander that the City purchased during the blizzard of 78 ran it well into the late 90s. Liked it so much I bought one in 86 and my youngest son totalled it on an icy bridge his first year driving, but he didnt have a scratch.
Wigwam700 said:Well with the end result you got your money's worth! :yes:
dmathieu said:Absolutely beautiful!
Turn those sealed beams so they are level with the truck, not the mounts.
A good bulb for the 15 would be # 1015, if you can find an old old one, (not easily found). The problem with the current 1015s is that they have the wrong shaped filament, therefor not giving you the best beam. The next best choice is # 1183, nice and bright. With the 1183, also get an old one, (readily available on ebay). Only the old ones have the proper v shaped filament.
jradue said:Is the 1015 a 100 watts bulb?
dmathieu said:It's listed as 60.8 Watt, and it is the original spec for the 6Volt Model 15.
The 12Volt 1019 is also a 60 Watt bulb.
I think they were advertised as 100 candle power, not 100 Watt.
jradue said:I just ordered some 12v 1015's which are 100 watt. We will see how they work.
dmathieu said:Probably a totally different bulb. Do you have a picture?
jradue said:
dmathieu said:Very interesting, That'll work!
I'm surprised that so many different bulbs have that number assigned to them!
Captain4164 said:Well, I'm just about done with the mergence warning lights on my Power Wagon. I added the two 6v sealed beams on the cowl. They are custom made, no manufacturer info on them, bought em from a guy on ebay that makes em. I like em cuz they are slim, not too big for the cowl. I added the two to the front and an amber to the rear. The drivers is the solid Ca spec red and the rear amber and passenger side are hooked to a 6v flasher. Only problem now is I need a brighter bulb for the Jr on the roof!
Whatta ya think?!
Nick, take off the front ring of the housing and twist the bulb in the ring to the proper orientation and re install the ring. That's all you should have to do. You don't need to disturb the mount.Captain4164 said:Thanks Dan. I tried to get the sealed beams straighter, but I can't, the base doesn't have enough adjustment in them. And I wanted them off to the side of the window enough that the window can still crank open. I know it looks weird, and Im still gonna try to get them adjusted to be straight instead of leaning over. But I don't think Ill be able to
Ok, Im gonna look into this bulbs and get a 1183. Thanks
dmathieu said:Nick, take off the front ring of the housing and twist the bulb in the ring to the proper orientation and re install the ring. That's all you should have to do. You don't need to disturb the mount.
As far as 1183, make sure you get one of the old ones with the "V" shaped filaments.
