Federal Signal 144
ex416
1,021
West Central Wisconsin
a light/beacon that is not seen all that often. picked this up earlier this year and thought i would share some pictures. i added the blue and amber bulbs for a little different look. it joins another 144 in the collection. believe this is a later model due to the square badge with the "FS" logo. the other 144 i have has a rectangular badge similar to the one on my 044.
3,725
PA
ok I feel I MUST insist on some video.. :p
Reactions: StEaLtH2
cmb56
746
Norrköping, Sweden
@ex416
Federal changed name from Federal Sign and Signal to Federal Signal in December 1975 so it is made some time after that date.
If you do not see any manufacturing date on the motor to pin point it closer we can only say it was made from about 1976 to around 1980 because I believe it was out of production in 1981.
Michael
Reactions: ex416
I love the 144! The sharp profile of the 14 with 4 bulbs...great light! That color pattern was very effective in the day...If I recall, OK Highway Patrol used the same bulbs in the last iteration of their 175s/176s before the went to 911EPs. Originally (60s), they were red/white, then replaced a clear bulb with a blue bulb and soon after added the amber bulb. It was especially effective on the interstate from long distance.
Reactions: ex416
stansdds
3,540
U.S.A., Virginia
Very nice Model 144. The big ID badge says it was made in 1976 or later. Take a close look at the motor, on the ink line that contains the 12 VOLTS line, there may be another letter and a single number. If so, the letter would indicate the month and the number would be the last digit of the year. Federal Signal started this on these Type I motors around 1969. My guess is, since this is a Type I motor, it's probably going to be a 1976 to 1978 production.
Reactions: OliverD and ex416
ex416
1,021
the letter/number on the motor is C7
ex416
1,021
this is the ID badge on my other 144, which is similar style to the one on my 044. apparently an older model 144 than the one in the original post. the letter/number on it's motor is A7.
shues
NW Indiana
The 044 and 144 contain parts you'd expect to find in a 174 or 176. It seems the history of the 044 can be traced back to the 074:
ex416
1,021
here are some pictures of the other 144 i added to my collection a little over a year ago. recently had the lamp holder assembly refinished/plated and just got it reassembled.
stansdds
3,540
U.S.A., Virginia
January 1977. The ID badge is the older version, but Federal Signal tended to not waste parts, so even though they went to a large, square ID badge for the Beacon Ray series, Model 14, and Model 184 during 1976, they may have still had a good supply of the small badges for their Models 044, 143, and 144 beacons.
So 044 is a flashing version and 144 is rotating? Is there a 043? I know there was a 143. Chicago Fire used them for a while.
No such thing as a Model 043.
Reactions: ex416
RetLt2020
