Federal Signal Cuda Signal Master Wiring Diagram
May 16, 2010
2,340
Torrington, WY
Does anyone one have one? I have look at http://www.fedsig.com and couldn't find anything. I need to know what wire does what. My plan is to hook it up via my Whelen Cencom Gold and use 3 buttons for ---> <--- <--->. Is that going to be possible?
I do have the TA built in, but I do not have the wire harness. I was hoping that I could use a couple of empty buttons on the Cencom. I would just need 3 buttons. Am I still able to do this? Also the TA has 8 wires and one red wire. How can I test it?
Download the Cencom manual from Whelen and look at page 8 and specifically at the group of wires marked "Optional."
On the Cuda you should have one larger hot (+) wire and series of smaller wires which are all grounds (-). You'll put the large wire in pin 9 and then put the grounds in the respective holes. While it's cheesy, I didn't have the plug either. I just put male amp connectors on my grounds and pushed them deep into the plug and it worked.
To sort out the wires, you can hook the large wire to a (+) source and touch the ground to determine which is which.I have a six module TA and this is what I got:
1-Brown
2-Green
3-Orange
4-Purple
5-Grey
6-Yellow
All of the Whelen plugs are pretty standard off the shelf pieces. If you'd like a plug that fits, taking your Cencom to a good shop should allow them to find a male plug that matches.
Ok I did just like you said. Here is the problem now. It dones't turn on via the Cencom. I went into the cencom settings and changed it to 6 head TA LED. Here is something I found too. I have 2 extra wires on the TA. There are two; one white and one blue. What do they go to? I wish I could find an install manual for this TA. The one that was posted above was for a lightbar. If anyone has one or has installedon please let me know.
If it's a 6 lamp arrow, the blue and white are wires for the 2 lights not there (aka, 8 lamp arrow).
Yeah it's a six head TA. That is kind of dumb to just leave 2 extra wires on the unit. That is why I usually buy Whelen products, they are easier to install. I will recheck everything today and see if I can find where I am going wrong. It still amazes me that I cannot find an install manual for it.
They just use the same cable for everything, hence the extra wires in the 6 lamp.
Checked all my wiring. I will wait and buy a plug for the amp and that might be the problem. How would I for sure check and see if my Cencom has the TA feature? I mean I am 99% sure I do as it has the female spot on the amp for it, but just want to make sure.
Is that a 12 place plug? I have the other side of it if so. Couple bucks shipped.
Have you checked the TA for function? The first thing I'd do is make sure the modules in the TA are good. Put the big wire to a (+) source and ground the others. If they modules work then you definitely have Cencom issues. Also, do you have the Cencom characterization done correctly? Six modules, LED, etc....
Yep checked all the LED heads when it first arrived. I have programmed the Cencom to 6 LED version. I have a Whelen TA amp plug on the way. My guess would be that the wire ends are not making contact in the amp. When the plug arrives I will hook everything up and see if that works. Should know in less than a week.
gabyluis_1
