Federal signal ford smart siren
medic550
178
pa usa
Looking for info on a federal made smart siren for ford crown Vic’s. Has a special ford plug on it and has a ford part number. 5W7J-70443-aa.
Tried calling federal and the guy I spoke with said he had nothing and passed me off to crown America which I can’t also find info.
Does anyone have a wiring diagram for this model? I appear to have a complete one with a small pigtail but don’t want to just start pumping 12 volts on wires.
Thanks
medic550
178
pa usa
Well i got some info. Apparently the outputs for the lights on this are negative switch low current. Basically have to use a relay on each output to turn on a circuit.
Hence why there is no heavy positive input on these.
steven.heather8492
5
Moro, Arkansas
So you have to hook up a relay between the lights and control box. Do you have a whirring diagram
medic550
178
pa usa
It has to be a relay. I used a Lin3 which it was able to flash but when i switched to a double avenger it went bonkers.
Its a very low current to activate an external relay.
Caldwell205
