federal signal streethawk bulb options ?
i have my streethawk with all stock lights. is there a safe but brighter bulb option for them ?
i dont want to melt anything but some stuff would look/work better if it was brighter i think.
thanks guys. :thumbsup:
Richard P
1,026
Sudbury, On
The streethawk is already the brightest halogen bar to date, especially with the h155 watt bulbs, you shouldnt have a problem. does yours have the 795 bulbs or the h1? maybe you have a bad ground causing it to be dim? it has the largest focused parabolic reflectors aside from the old target tech bars.
the 795 is a 50 watt halogen, the h1 is 55. Unless you use a large mercury vapor streelight bulb, you already have the brightest
03crownvic
1,033
Louisiana
H-1 bulbs are available in 100 watts but I wouldn't recommend using them in a lightbar. 55 watt bulbs are the intended ones to use, as they are very effective, especially if you keep your lenses and/or domes cleaned and polished to prevent haziness. The extra heat generated by the brighter bulb would be a major issue, especially in an enclosed space under a colored reflector filter or inside a smaller outer dome, even though Code 3 commonly used them in the fast rotator under an MX7000 center dome. Plus, any reflector's surface would either flake or tarnish faster if it is metal or melt completely if it is plastic.
JohnMarcson
May 7, 2010
10,926
Northwest Ohio
I had 100w bulbs in an XL5000 and it cooked the METAL reflectors.
Pete L.
Virginia (south/central)
+1 on what 03crownvic said. You may want to check your rotator reflectors.
The StreetHawk came with both alum. and plastic reflectors. If they're
dull, that will effect the flash.
Pete
Pete
nothin wrong with it now. just was thinkin more power tim allen style. :crazy:
May 22, 2010
787
Columbiana County, Ohio
H1 Bulbs come in 55 watt or 100 watt options.
In my opinion I hate lower level flashers, they distract the attention from the rotators.
Just my $0.02
Pete L.
From you're picture it looks like you plow snow to make money ;)
I would make all the lower level lights clear takedowns so
you can see what you're doing in those dark parking lots :yes:
Had to say it--
Pete
na its my play toy . :razz:
i just wanted to make sure i was seen to be safe.
do some escort service work for my farmer friend at times with his big equipment moves. he loves me in front as i bring 99% vehicles to there knees and watch out. :hail:
i am redoing the truck this summer and will change it up a bit to make it better all around truck.
cmb56
746
Norrköping, Sweden
I do not know for the US but here in Europe there are some special versions of the H1 55 Watt bulb that in some different ways give a higher light output with the same power as the standard bulb.
All the major manufacturers like Osram and Philips has these bulbs.
The life time might be shorter in favour of a higher light output.
Here are some of the different bulbs fom Philips:
BlueVision (BV)
SilverVision (SV)
NightGuide DoubleLife (NGDL)
X-treme Power (XP)
VisionPlus (VP)
EcoVision (ECO)
Premium (PR)
joecfd1
