Skulldigger
Has anyone tried to restore these old faded tags? I worked yesterday on several techniques and found one that works really well and with just a little effort. You can make them look fully new or a little aged like mine.
Here is the tag off of the Model 17 military spec I have been working on.
Although I liked the look of the silver tag, it just blended in with the chrome and was not visible at all.
I removed the tag and sprayed it with several light coats to give good coverage. I allowed the paint to dry for several hours to ensure it was good to handle. Then I took 1000 grit sandpaper, laying it flat on the table and then briskly rubbed the tag across the sandpaper to remove the paint on the high spots. You can not hold the sandpaper and rub across the tag as your fingers will push it into the recessed areas. (trust me). Once you have removed most of the red from the high areas, use either a Q Tip or a smooth rag and your finger and with a little lacquer thinner on it, remove the redness from the flat areas. Touch up as you please. Sanding will create some dust and darkness which can be removed with light brushing from the thinner. Remove as much of the darkness as you want for a new or used look. I wanted mine to match the age and scratches of my base so I left some of the "dirt"..
I think it came out pretty good ! Anyone else tried this?
