I think there should be a LED or two on top of the reflector , where the screw goes.
I want a cannon designed for STT use.
I was thinking something like a bigger heat sink to allow for extended full power operation....traffic, stop lights etc. Not have to use resistors or modify the light.We are already doing that with the current ones...
All,
Your input is greatly appreciated on this project. We are currently working on the "Cannon Plus" HAW. See attached images. I won’t bore you all with the details since the images are self-explanatory. Do you guys agree with the concept? The engineers requested feedback from the sales team so I thought reaching out to you all might help.
I think something similar to the Fairy, with the diodes facing different directions, and adding a diode top facing. Its a toss up, have diodes all face one way and use optics to disperse the light, OR, angle the diodes to do the light dispersing, and adding a top firing one or two.I think there should be a LED or two on top of the reflector , where the screw goes.
Yup agreed. One reason I was kind of surprised when the Cannon went with the other HAWs and put them all on a flat plane. I do think it would be similar one way or another with the optics one proposed, or as I stated, angling the diodes themselves to fill a reflector, and adding that additional diode or two facing straight (would make sure light gets dispersed in ALL directions in 180°).I always LOVED the fact that the Fairys had 2 LEDs on 4 different angled surfaces... VERY effective at filling a lighthead... But this new Cannon designs looks like it will fill it better...
If you want/need a guy to test some, I'll be more than happy to... lol I will be getting a new vehicle soon... lol
This is my reply...All,
Where are the Cannons on your F-150? Do you have pics or video?2010 f150 fx4
cool if it could snap on over it , though.Probably doubtful being as it is part of the cap that seals the device. Having people break that seal is asking for trouble in my opinion.
Yeah, the new product info is posted herecool if it could snap on over it , though.
I don't have any recent pictures, but I'll grab some after work tonight.Where are the Cannons on your F-150? Do you have pics or video?
I've got an idea or two poking around. My only issue with Feniex stuff is that the pattern change and sync is a ground input. To me that means that I have to take extra precaution to isolate that input wire to ensure that lights don't end up changing patterns if I hit a bump. In my mind, the simplest way to avoid that is to remove the internal flasher all together.There isn't any issue with those on external flashers.. Generally the cost of a "dumb" lighthead is not much more than the regular light head.... what ya kicking around in your head foxy?
If using on external flasher, I will put a red or purple butt connector on the ends of the pattern and sync independently. If I ever want to go to the internal flasher, the connectors are there and it protects the end and exposed party of the wire. been like that for 3 years and never had an issue with them changingI've got an idea or two poking around. My only issue with Feniex stuff is that the pattern change and sync is a ground input. To me that means that I have to take extra precaution to isolate that input wire to ensure that lights don't end up changing patterns if I hit a bump. In my mind, the simplest way to avoid that is to remove the internal flasher all together.
They are shippingLense option looks like it would get the job done.!
Are the three mode units shipping or still in works?
Thanks
Thanks Fever.. Is there a low power pattern that can be set to one of the triggers to use as a park lamp?..how would a dual color unit differ from a single color.??.... Thank you for the knowledge.!.They are shipping
Just installed 4 of the latest version Feniex Cannons today in one of our trucks to replace a Whelen strobe system. As always, the cannons are beyond great but now with the new quick disconnect, they are even better! Should something happen, I won't have to undo all the wiring but simply disconnect the lighthead and plug in the new one. Keep up the good work, Feniex!
Does anyone know if the new Cannon 360s will fit in the standard 1" hole from a 7440 incandescent bulb?
I'm looking to replace my turn signals with them, and would rather not have to drill holes or damage the original housing. If so, what is the best way to mount them, since I assume they won't screw in like the factory bulbs?
Thanks.
