Feniex Cannon LED Hide-a-way!
Carlos SpicyWeiner
May 3, 2012
5,233
Lakeland, Florida
Here are the basic specs:
5 year warranty
Voltage: 9-15 VDC
Includes 6 feet of cable
12, 4-watt LEDs per bulb
Includes surface mount flange
Dual/Multi-Color options available
Features more than 15 flash patterns
Inline driver allows for simple installation
Lens designed for optimal light distribution
Dimensions of bulb: 1" H with 1.5" diameter base
Aluminum base with advanced thermal management
Free of radio frequency or electric magnetic interference
Capable of synchronizing and alternating with multiple light heads
MAP Price, List Price, Videos/Pictures will be released within a week.
I will have pictures on my site shortly and will post them up. So be clicking on my signature picture periodically to check for updates!
This was done quickly but I'll update it accordingly
Carlos SpicyWeiner
May 3, 2012
5,233
Lakeland, Florida
Feniex Fairy will continue. If the Cannon takes over the market they might readdress the Fairy.
EMT-BLS
2,640
Waterbury, CT
That's not what I heard...I was told they'd be removing the Fairy after a unspecified amount of time.
Carlos SpicyWeiner
May 3, 2012
5,233
Lakeland, Florida
They said only if/after the cannon takes over sales. I still think there is function for the Fairy. The fairy as it sits is still one fo the better LAWs on the market
unlisted
May 20, 2010
7,333
NA
photos and/or videos and/or detailed weblinks - or it didn't happen!
(that should be a rule for any equipment postings...)
Carlos SpicyWeiner
May 3, 2012
5,233
Lakeland, Florida
I'll have pictures posted tonight with a link to my website. Unfortunately I had to leave Fever Central Command for a few.
Solvarex
561
Canada
Wow. It's not often I'm impressed with new lighting products because they always seem to be lacking something. If the Cannon lives up to all its specs I am SOLD. Something like this is long overdue and I am genuinely excited to buy some!
EMT-BLS
2,640
Waterbury, CT
Same here...I saw it in action. It looks effing cool.
Carlos SpicyWeiner
May 3, 2012
5,233
Lakeland, Florida
Gentlemen, I can't explain how excited I am for next week to come. Im more excited about using them on my car then I am about selling them lol
theroofable
1,379
New Jersey
Too bad the brake mode flashes 3 times first instead of going into steady burn. There is no point of that. :nono: Otherwise it is great, but that would keep me from using it.
twodogs603
1,196
Norfolk,VA
Depends on if its a slow flash or a quick flickerflash.
EMT-BLS
2,640
Waterbury, CT
It's not a warning flash pattern...it's a STT light, with a very fast triple burst, like any fire truck or ambulance.
Carlos SpicyWeiner
May 3, 2012
5,233
Lakeland, Florida
it is a quick....
Here is the thing.... you can program it for steady burn on the input. it just has a special brake mode that will be used for the vehicles that want that function. I find the function incredibly effective when I see our ambulances here using it. I actually want some for my sportbikes and harley :)
Eric1249
2,277
Waukesha WI USA
FEVER said:
it is a quick....
I was thinking for my Harley as well. The custom tillights that I have now are terrible
Tom
3,083
Taunton, MA
Wow, it really sounds like a great product! I can't wait to get my hands on some
NERT11
196
Ontario, Canada
So, just to make sure I understood correctly... I could take the stock fog light bulbs out of my truck (09 F-150), and these will fit in to their place, get them in green and white, use them as fog lights where the white would steady burn, but when I activate my lights, they will begin flashing green and white? This would be the ultimate! Has there been any word on pricing yet?
EMT-BLS
2,640
Waterbury, CT
That's the gist of it...Pricing has not been released yet, but should be shortly. Or so I'm told...
Jman423
Sep 10, 2010
3,391
United States
They were designed with that concept in mind... a replacement of the OEM bulb instead of drilling another hole. Wires will have to be cut/spliced, and the hole will not always be a perfect fit... some boring may be necessary depending the vehicle and housing type.
From the information I've seen, these seem very promising.
Carlos SpicyWeiner
May 3, 2012
5,233
Lakeland, Florida
Yup. I believe they said the mounting circumference is about one inch in diameter.
CPDG23
835
Ohio
These have some serious potential.
I have avoided adding HAW's to my vehicle solely because of the drilling.
NERT11
196
Ontario, Canada
I can see this working in well with my purposes. I've got POV lighting on the FD side of things, and I'm in the process of shopping for the avatar for the business side of things. I could run both purposes off of one unit. And I'm really loving the idea of the Cannons acting a regular fog lights until you activate the warning mode
HILO
2,781
Grand Prairie Texas
I'm sure you mean driving light and not fog light. Big difference.
I like the dual more idea for the front turn/running lights on my V-Star, as well as rear turnsignal/brake light. I wonder if the turn signal will over ride the brake light.
I've been thinking about these....
Motorcycle LED Dynamic Clusters
...but if the Cannon has better output, I'm in!
Strobesnmore
382
Westerly, RI
So are some of the diodes dedicated to brake or turn signal and do you have to order them based on that secondary use? Will you have to modify the factory housing to make them fit or will they have some adapters or similar? Looks similar to original Whelen LAW hide a way with center screw. I do like the 12 diode for 2 color use as I hate dual colors in the 6 diodes most companies offer. We don't stock or offer them due to the decreased output.
Carlos SpicyWeiner
May 3, 2012
5,233
Lakeland, Florida
No you will not have to order them for that use. Let me clarify the process... The Cannon will have two POSITIVE "Input" wires. One wire is considered "mode 1" one is considered "mode 2". You set what you want the mode to do via the flash pattern (steady burn) for turn signals. when that wire receives power the light comes on in that mode (steady burn) but works off turn signal flasher to blink.
Then when you put power to the second mode wire... it goes into that flash pattern for the other half of the LED's. Mode 2 will ALWAYS take priority over mode 1. So if you are using it as a brake light and a warning light. You set mode 1 to warning and mode 2 to brake so that no matter what you ALWAYS have brake lights.
Jan 19, 2012
304
Normal, IL
I gotta say as a master dealer ... I'm kinda looking more forward to re-doing my entire demo vehicle here in about a month. Thank you Uncle Sam and Feniex :-D And yeah... I guess we'll sell some too!
Carlos SpicyWeiner
May 3, 2012
5,233
Lakeland, Florida
That is exactly what I'm looking forward to the most!
I just re did my patrol car for the second time in a year... here comes round number 3. I can't wait.
Reactions: Mrlunchbox
idk
