Fusion ILB HELP!!!
OTFD211
142
Cleveland,Oh
Ok guys here is my situation..... I have a split dual color (R/B & A) Fusion ILB. I also have 2 Fusion 2X in dual R/A. I'm attempting to take the dual R/A modules out of the 2Xs and swap them with the B/A in the ILB so that I can have all RED or AMBER depending on mode selection. Here's my problem....I can't get the R/A out of the 2Xs to work in the ILB. I've discovered that the 2X heads are self contained but can't figure the wiring correctly on the ILB. As soon as I hook up the sync wire the head stops working. All lightheads are interior only and have the 4 wires...RED/AMBER/BLUE/BLACK. Here is another issue I've found...this might be the correct functions I'm not sure....
2X head: R- mode 1
Y- mode 2
Blue-Sync
Black-Ground
Dummy head: R- nothing
Y- nothing
R/Y together-mode 1
Blue/Black -ground
ok guys I realize this is a little long but trying to give some background on what I have gotten so far. I assumed before I started this that all that was needed was to put each mode into steady burn and I would be good. I already have a email into Feniex but I think I will get a faster reply from everybody here. Anybody have any input/ideas? Is this even possible? Thanks for any help you guys can give. Bill
bullfrog4ever
336
Indiana
You'll have to get new dummy heads if you want to swap. Fusion surface mounts (which is what's in the dash light) have an internal flasher which doesn't not play well with flashers and will not be compatible with the Feniex ILB flasher.
With the dummy lights from the lightbars and stick lights, you have to have constant power/ground, then the yellow and blue are color 1/color 2 (I believe that's the setup.) But regardless, you'll need new dummys. Any dealer should be able to help you out.
OTFD211
142
Cleveland,Oh
That's what I have been finding out. I have decided to post it in the "For Sale" forum. For the amount of $ I already have in this and to add 4 dummy heads wouldn't make sense money wise.
idk
