Grlstr clear lens using 52/500 lens half filters?
A-TAD
5
South Eastern PA
Will a half filter that you use with a 52 or 500 series clear lens fit a clear grlstr lens?
I know the 52/500 lens are longer but are they the same height also?
Just asking because I see the 52/500 half filters for sale but never see the grl half filters, if they made them.
02-0362801-** is the part # for the grl split lens with the ** being color choice.
I am not sure if this was a clear lens with filters or two half lenses bonded together
Thanks for any info on this matter.
I havent ever seen filters for a grlstr, or grlhal series light head, just spliced outer lenses, I do have 1 500 series split filter and i dropped it in a grlstr lense I have, it fit, its too wide of course but you could easily trim it, the only down fall would be that to for the retainer tabs will be removed, so the 2 1/2 filters would either need to be glued together, or 2 the lense. the hole for the lense screw is off just a little bit also, bit you could enlarge that no problem.
I have 2 blue half filters available if you need that color. They have already been trimmed and should fit your grlstr lenses.
For $5 shipped, they're yours. Let me know, thanks.
BlueOrange
