quick question, what color does each wire pint go to on haw cables? I need to assemble the AMP connectors, but dont know if white coes in the middle, or red etc.
ncfireman1918 said:Take apart a ball point pen, and use the top end of the ink tube to flatten the tab (just push over the pin). Pull the wire back, and at the same time, pull the ink tube off. The tab will usually spring back up, it not, use a small screwdriver or knife blade to pry back up.
Chris
