Help a federal newbie
53cub
8
Virginia
I have lots of 12 volt and strobe light experience but am new to federal signal lights. I got 10 bars for such a steal I couldn't pass them up. But now I'm not sure if I'm missing something or they're not working. I tried one of the Legends LED bars and couldn't get anything to work at all. It had like an 8 gauge red wire, 8 gauge black wire, then 4 sets of twisted wires (8 total, blue and blue/white. Orange and orange/white. Brown and brown/white and I forget the 4th set off my head) the wires are all cut about 5" from the bar and fron what I can tell it seems I may need some type of controller for these?
Next is the vista ricochet the non rotator style, I get the alley lights to work with the orange and the green wires, then got what I believe are the spot lights (two smaller white lights on front) they steady burn or flash side to side. But I can not get any of the upper 8 lights to work or what appears to be the traffic advisory bar on the back to light at all.
Sparky_911
Supporting Donor
May 15, 2013
2,658
Central Illinois
Manuals are available on Fed Sigs website.
Legends should be easy. 12v+ to red 8ga and 12v- to 8ga blk then 12+ to any of the colored/ striped wires.
tsquale
Oct 12, 2010
10,537
Minnesota, USA
I do believe sparky is incorrect. Both Legends that I had required a serial interface module to work. Don't start applying 12v first without looking for the manual or you may fry it.
Reactions: Sparky_911
tsquale
Oct 12, 2010
10,537
Minnesota, USA
That said, I believe Federal did make a few basic Legends that didn't need the module but it's my understanding that the vast majority do need them
tsquale
Oct 12, 2010
10,537
Minnesota, USA
For the ricochet, the arrow should have its own cable that needs a controller to properly function. I'm not sure on the strobes though.
53cub
8
Virginia
That's the same diagram I had found, well guess I'll get into testing the rest of the lights to see what I can merge into full working sets. Thanks
Sparky_911
Supporting Donor
May 15, 2013
2,658
Central Illinois
My bad. He's right on that. I think they sometimes call those breakout boxes too. Im thinking of the Whelen LC Freedom bars. Same wiring setup but no serial required.
53cub
8
Virginia
That's what I was seeing but hoped I was looking at the wrong thing. Looks like a cat5 cable and the module is needed. I was hoping I'd luck out, to get these working without buying a bunch of parts to find out the lightbars might not work.
Thanks again guys guess I'll start looking for the parts and figure out how deep I want to go into these bars.
53cub
8
Virginia
I just found this in assume it's simple match wires. But should there be a plug for input also? Each one I find one has one plug. Once I got a couple minutes I'll be downloading the manual from federal signal also.
53cub
8
Virginia
So my vista light bars I have 7 of them, all 7 the alley lights work and the lower front spot lights work but nothing else. I'm going to look more into the controller after the holidays because I find it hard to believe all 7 have the same functions working or not working. Thank you again guys for your input
Caldwell205
