Help Deciding Please.
Scoops
Scott Co, IA
So i have the options of either a Whelen 8 Head Liberty with the rear being amber for traffic advisor and 3rd brake light avenger OR a fully populated liberty red/blue all the way around and a lower 8 head inner-edge all amber for traffic advisor.....This will be going into a CVPI. Well i cant decide so i need a little help on this one.
Thanks in advance.
I would go with option one. Not a big fan of TA's being down low (ie rear deck). But thats just me, you do what you wont to do!!!
Option 1 as well, better 24 hour visability. A liberty by it's self is 100% effective, and adding the deck lights will give you a better side street/DWI testing option without over kill. Plus an arrow needs to be as high up as possible for better distance.
I like the idea of the fully populated Liberty, so long as you have all the reds on one side and the blue on the other side and flash them alternately (mixing them together gives you the purple effect). Having the inner edge for traffic advisor is great and all (or just more warning in a third color), but the Liberty with built in traffic advisor would do just fine (so long as it's a newer model with that option).
I would so much rather have the second one because you are having more leds and more light heads going on instead of just limited ones with option . Something you might think about is doing the on the second one is doing amber in the back instead of red/blue and then do the inner edge with red/blue. Ideally you would want to have the amber as high as possible. Also i think 8 lightheads in a liberty is just not going to work it's just not enough light. Of course just what i think and i hope that this helps.
I would use option one for precisely the same reason. Cop cars these days use entirely too many lights.
love the second option and the Florida DOT Officers have that setup on their new CVPI's with the inner edge and lightbar synched and boy let me tell you it's sweet :p
Really??
How much is enough then? :?
rwo978 said:
Really??
I think he took it as there was only going to be 8 heads in the whole bar, and what i meant by 8 heads is 8 in the back including the corners and 8 heads in the front including the the corners for a total of 16.
Thanks in advance.
i honestly dont think u'll go wrong with either (not to mention the fact that you're lucky enough to have options for your patrol car). i personally prefer option 2 and think that a half blue and half red lightbar with a separate T/A would be better. a buddy of mine's cvpi has a liberty with a rear amber traffic advisor built-in and he only uses the amber on V&T's b/c he hates the flashing amber blurring with the r/b corners and wishes that his crown vic had the T/A on the rear deck like the other units in the dept.
Well now knowing that there will be a fully populated bar then it makes sense too go with option 1 but if you read the original post the way he makes it sound as if 8 heads in the total bar and then he second option said FULLY POPULATED why didn't he just say FULLY POPULATED for both of them? and really his question is just inner edge ta or 3rd brake light avenger.
My 08 CVPI had a fully populated liberty and thats it (department wouldn't let us add lights) and it worked fine for me. Mine was red/blue in the front and it had the arrow stick with red and blue ends.
Gotcha
Just thought, "a full liberty not enough.... wow" :o :shock: :lol:
id go for the liberty with the TA, i agree that police cars are being put out there with to many lights, and that your TA should be as high as possible, using the fully populated liberty with the lower inner edge would be IMO to much lighting to the rear and just to much going on back there
Ziva
