HHS4200 Command Issue- Need some Help
Scffle
10
Lexington SC
Went to dim down some cruise lights on a unit that was installed 2 weeks ago and after transferring the file the vehicles horn continuously blows until I unplug the unit power. I've reuploaded the original file, along with started from scratch to attempt to troubleshoot it with no resolve. I've also went through and deactivated anything that is tied into the horn ring just to shut it up with no luck.
Anybody have a clue?
NoLimitSquads
335
Minnesota
Ive had this problem before, I cant remember what it was though, it hasn’t happened in awhile. I feel like when I had it happen, it was something to do with an event that I created. But Ive never had it not change by going back and undoing what made it happen. Have you tried transferring the file while the power is still unhooked?
NoLimitSquads
335
Minnesota
You tried just transferring a default file into it, and it still turns on the horn? Its definitely a glitch in the programming somewhere, because the wire connected from the horn should be an input only. They talked about this in one of the trainings that I went to, but for the life of me, can’t remember why or how this happens.
Caldwell205
