hlf for audi??
emtmike
763
0
brooklyn,ny
i was wondering which hlf would work with audi cars, i have been thinking about putting in hlf for sometime, but finally decided to do it, i feel it will really help out ,
any ideas or places where i can find out. all the help is much appreciated
thanks
emtmike
Are the lights the HID's? If so, you're out of luck. However, if they high beams are still halogen, you should be able to hook a flasher up to them. What kind of flasher depends on whether it's positive or negative switched...
What model is it ?
I would strongly discourage playing with HID housing on those Euro wheels, and go for the foglight housings instead.
ehh always wanting something else, plus hlf are the most effective warning power you can have, even though some may disagree mr civic
I would steer clear of messing with the Audi electrical system. I had an '01 A6 that was nothing but problems and it definitely wasn't cheap too fix.
yea 911 im still driving her, she is putting up with my abuse, plus i got the lights , well the other lights installed into her, for now , no clue about the explorer, but back on topic, too late to steer clear of messing with it, i have a few leds , siren speaker and strobes in the car, just wanting a simple hlf to finnish up everything
I'm not sure what HLF you would need. Your local Audi dealer should be able to tell you what type of headlight system your car has and that should enable one of use to find you a flasher. Also, you could always go with some white LED spot/flood lights on a wig wag patter to give you the effect of a HLF if there is a place to mount them. Plus then you could have them steady burn for TDs or scene lights ;) Only down side to the LEDs is that they will be more expensive than the HLF :p
Dstewart02
