By putting a smart vector on a rag top.
This is the first winter I am going to be driving this Tracker instead of storing it. I shaped a crossbar out of foam and fiber-glassed it for the strength. It is only up for the winter but easily removable with 4 bolts. I put 4 crush nuts in the bar connecting the A and B pillar to bolt the bar to the vehicle. I had a 7 pod Smart Vector on another vehicle that I had to part with (hence not driving this in the winter) and got to thinking. I cut the 7 pod down to a 5 pod and moved the Smart pods over one to the center. I used fiberglass to make a new back cover then put a piece of angle-iron over the back so I can mount STT to it. I let the iron stick off the edges about 4 in so I can mount a marker on the front of it too.
