I currently have a 2005 Tahoe and am replacing my STL junk with some higher quality stuff. I currently have the following:
Have 4 T3 grille lights, do 2 red and 2 white stacked next to each other and synced so that they act like one big head, or have them split over the grille?
Possibly have the other 2 T3s on an intersection bracket? Or side warning in a window?
Have the Avengers mounted in the top of the rear, mounted so I can open the hatch and they stay in position.
Don't really have a place for the LINZ6s, possibly put on an LP bracket towards the rear? Or would those be better suited as intersectors and leave the Avengers only to the rear.
If anyone knows if a Cobra dash will sync with the T3s it would be appreciated, same with the Avengers with the LINZ6s. Possibly have the front white on a separate switch on the box so I can kill it if need be. Thinking front warn, rear warn, white, which leaves me with 3 blank if I add a TLF, or scene lights.
Overall, it's overkill for what I really need, mostly rural responses to the station and scene on medicals. I appreciate any input the gurus on the forum can offer, because I don't exactly know how I want this laid out.
- Feniex Cobra 2x, it's the v2 with R/W split heads
- 8x Feniex T3s, 4 red 4 white. Have 4 L mounts and a LP bracket. One red doesn't work, so I will either warranty it if I can find a use or just install 6.
- 2x Avenger duals, R/A
- 2x LINZ6 red
- SOS 6 switch box
