stansdds
I found this while snooping around eBay this afternoon. The seller claims it is a Flashball, but the mirror and bulb are mounted backwards and in the wrong place and the flasher is not correct nor is it mounted in the correct spot. The label on the dome retaining band also looks very odd. As far as I know, Flashball's came with labels that read "Flash*Ball", this one reads "Fire*Ball". Also, the model designation stamping looks odd. The "F" in FB and the "F" that designates it as a Flashball appear to be different fonts, almost like someone took a FB-1 label and doctored the "1" to look like a "F". The base also appears to have an excessive number of holes in it, more than any Flashball or Fireball that I have seen. Could it be that someone has tried to home brew a Flashball from parts?
Vintage Fire Ball Federal Sign and Signal Corp Model FB F Light Works | eBay
