Issues with HT-1250/update
deputychief301
Senior Member
2
Snow Belt, Michigan
I have a HT-1250 that been a excellent portable and hardly used it, One day went to
turn it on and it would not turn on or power up. Does this radios have an internal fuse
I tryed different batterys. Or is there a battery inside of the housing.
Jim Rogers
deputychief301
The radio does have an internal fuse. It is a surface mount fuse on the main board. I don't have a manual for that model, but the fuse is located right near the battery contacts. It is usually a 3 amp fuse on portable radios. The part will be labeled on the circuit board starting with "F" then some numbers. Might be F501 or something similar. The on/off switch/ volume pot may also be bad. That is a common failure part for those radios. They will usually break the other way though. They usually will remain on with no way of turning them off or adjusting the volume.
John L
Sparta NJ
The same think happened to me last night, im gonna bring my in tonight for repair.
I took my ht-1250 apart and discovered a battery ,that looks like a watch battery
instead of a fuse. I called radio and sounds like its going to be a dealer item only
If there is any dealers out there that give me a quote
Battery number is ms621,there is a smaller number over top of the ms621 which is
811
Motorola ht-1250 ser#749tzc5855
mod;aah25kdft3749/limited keypad
just went to turn the radio on and portable would not power up
I just had it refurbished about three years ago
thanks
Jim Rogers
Northern Lights/Sirens
811
thanks
Jim Rogers
I sent you a PM but:
deputychief301 has exceeded their stored private messages quota and cannot accept further messages until they clear some space.
Anyway here is something that may help you:
http://www.electronicplus.com/content/ProductPage.asp?maincat=ba&subcat=bwa (It's a 364BP on this page)
http://www.smallbattery.company.org.uk/sbc_ms621.htm
http://cgi.ebay.com/NEW-Seiko-MS621FE-Rechargeab-le-3V-Back-up-Battery-/280594797188?pt=US_Batteries&hash=item4154c0d284
http://cgi.ebay.com/Seiko-MS621FE-Rechargeab-le-3V-Battery-w-tag-NEW-/160466892698?pt=US_Batteries&hash=item255c92779a
Zach
roul
