Justice bar upgrade?
May 26, 2010
26
Lubbock, TX
I just received my new lightbar for work, and already want to update/upgrade it. It's a 50" with all red to the front, red rear corners and amber led arrowstick (6, not 7). It also has the LED alley lights and takedowns.
My first question is: ho w hard would it be to add the center (7th) directional module and at what cost?
Next: How hard would it be to add a center module to the front, and at what cost?
RL1
1,643
Ga
From what I've read, it's supposed to be pretty easy to add. Like pdk9 said, they should just snap in. The hardest part is making sure you get the rubber seal around the lens edge to not pinch when you put it back together.
fp13-2
316
Harrisburg, PA
I added both to mine, and all you do is unscrew the four screws on the top, plug the module into the plugs that are sitting there, screw it in with one/two screws, and you're done.
deputychief301
Snow Belt, Michigan
Make sure the gaskets are properly back in place or the only thing you'll
have is another justice bar leaking or drawing moisture as most whelens
products do. I would get a hold of Patrick/Sarah @ priority1 and they will
steer you in the right direction,
Jim Rogers'
Deputychief301
Kbellinger01
