Liberty patterns
chief
Junior Member
12
0
USA
I don't have we-can liberty and the standard 13 or so patters on it are not impressive to say the least. Is it possible to change patters for individual light heads with scan lock wire by disconnecting other light heads from the lightbar?
or will it change patterns for the whole light bar without having any regard to what light heads are plugged in?
Disconnecting the heads is not what you want to do. That will make no difference. You need to make sure the control line for the pair you want to adjust is the only one connected to power. Then change the pattern for that pair to whatever you want. Then... repeat process for the next pair and so on. You can have a different pattern for each pair.
Someone from here took this picture a while back.
[Broken External Image]:http://www.porteck.de/pics/liberty-connector.jpg
Are the wires below the circled arrow stick wire are pair control lines?
How does liberty pair lights? if this is the back for example
corner led : led : led : led : led : led : led : corner led
1 2 3 4 4 3 2 1 light pairs
1 2 2 3 3 4 4 1 light pairs
The connector circled only controls the traffic advisor function.
Connect 12v to the wire color of the pair of LEDs you want to change the pattern on and then while activated apply 12v to the scan-lock wire to change the flash pattern.
*Remember to only activate the pair you want to change or else you will change the patterns for every pair of LEDs at the same time.
The wires you are looking for are as follows:
Wire Color Function Fuse
GREEN . . . . . .Front Corner LEDs . . . . . .1 AMP BLUE . . . . . . .Rear Corner LEDs . . . . . . 1 AMP
GRN/WHT. . . .Front Outboard LEDs . . . . 1 AMP BLU/WHT . . . .Rear Outboard LEDs . . . . 1 AMP
GRN/BLK . . . .Front Inboard LEDs . . . . . 1 AMP BLU/BLK . . . .Rear Inboard LEDs . . . . . 1 AMP
WHT/RED. . . . . .Front Center LEDs . . . 1 AMP WHT/BRN . . . . .Rear Center LEDs . . . 1 AMP
WHT/GRN. . . Right TA . . . . . . . . . . . . .1 AMP WHT/BLU . . . Flashing Alley & T.D.’s . . . 1 AMP
YELLOW . . . Pass.-Side Alley Lights . . . 1 AMP WHITE . . . . . Driver-Side Alley Lights. . . 1 AMP
WHT/BLK . . . Take-Down Lights . . . . . . . 1 AMP WHT/ORG . . Cruise Lights & AUX . . . . . 1 AMP
WHT/YEL . . . . . Left TA . . . . . . . . . . . . . 1 AMP VIOLET . . . . . . .Hi/Low Power. . . . 0.5 AMPS
WHT-VIOLET . . . . . .Scan-Lock™. . . . . .0.5 AMPS
NONE. . . . . . . . .RFI shield drain / to ground
WHT/GRN + WHT/YEL = Split TA
Hope thie helps. :D
I'm not that advanced when it comes to electric stuff. How do you connect the 12v to the LED pair wire?
Can I just unplug all the other wires and leave the ones I want to change and just keep plugging and unplugging pairs until desired pattern is set for each pair?
Is the bar installed? If not, I don't think just unplugging the lightheads from the harness inside the bar will solve that, as there's still power going to each pair. so, touching the pattern wire will still advance the patterns even though the lightheads are not hooked up.
If the bar is installed, you're going to have to trace the wires to wherever the switchbox is and start disconnecting stuff.
Resurrecting old thread. I took a picture of the liberty's guts.
View image: liberty
Can I run the wire from the directional arrow stick connector to those raised metal "aux" things for power? Zoom in on the picture to see direction.
I have the wire and someone suggested I use 1-pin amp male connector, what size connector do I need to get it to stay in the arrow stick module without it falling out?
If I recall correctly the I/O board either does TA patterns or it doesn't. If it does, the wire(s) you will need to control it are in the main wiring harness that connects to your switch box just like all the others.
Just like you are applying +12VDC to all the other wires to turn on light heads you will need to do the same to activate the TA patterns (again, if your bar has that feature).
White/Yellow - Left Arrow
White/Green - Right Arrow
White/Yellow AND White/Green - Center Out
This can be done with 2 switches... one activates left, the other activates right, and both on together activates center out.
By the way... Did you get the pattern thing figured out? Below is a video of a Liberty I have for sale. You can see that some of the lights are on different patters (specifically to the rear).
It sounds like everything you want the bar to do can be done... given you have the correct bar...
http://www.youtube.com/watch?v=nt5JAG16AK0
I figured out how to change patterns and even how to change patterns with sync enabled. I just dont know what kind of connectors do I need on my wire to have "sync" on at all times so it doesn't slide out and where to run the sync cable after I connect it to the traffic arrow.
Those are just standard amp/mate plugs, pins, and sockets. I have the parts if you ever figure out what exactly you need.
Running +12VDC to the empty lead in the 3-wire amp connector for the TA in the SX series Liberties will sync the full bar and has a variety of patterns, just tap the scan-lock to cycle through.
Neutron5
