Light controller/siren similar to PA640
110
10
SF Bay Area
I have used a Federal Signal PA640 before and I liked how you could program auxiliary buttons to latch to the slide switch. I’m currently looking for another siren/light controller that has the ability to do the same thing. Any recommendations other than a PA640?
MtnMan
1,533
Eastern PA
SS2000 Smart Siren
110
10
SF Bay Area
Latch, meaning be controlled by the slide switch?
Correct. For example when you put it to code 1 the controller activates certain user programmable outputs. Code 2 activates code 1 outputs plus additional outputs.
In regards to that SS2000 hour programmable/customizable is it?
EMT-BLS
2,640
Waterbury, CT
In that regard, the SS is perfect. You can activate outputs by pressing the corresponding button (Button 1 = output A, etc), or you can have the slide switch activate one or more button/output based on the slide switch's position (1, 2, 3).
110
10
SF Bay Area
How customizable is the SS? Like if I want to switch where the manual and air horn buttons are? On the PA 640 I liked how the manual and AH buttons were right by the slide switch which I could manipulate with my index and thumb lol
EMT-BLS
2,640
Waterbury, CT
No, you can't move siren tone buttons around. Just enable/disable. The SSP (next gen of the SS), you can, but the price point goes up significantly.
Reactions: 110
110
10
SF Bay Area
Anything else not made by Federal Signal that has the latching outputs? And maybe customizable?
Jhaberny
