Lin3's aren't syncing anymore?
Fast LT1
Veteran
2,022
Sedgwick County, KS
I installed 2 white lin3's about a month ago and they stopped syncing not sure why? They are on the same pattern, is there anything that would cause this? Oh and all wiring is correct, double checked it many times!
Thats odd. Are you sure the sync wire is still connected?? You might have to pull the wiring apart and re-do it to find out what is up.
Did that too, plus one is a slightly yellow-ish color while the other is bright white? Not too sure, i'll have to make a vid.
Bad ground?
Checked ground, and re-did it still same problem. Guess i'll give a call to whelen soon.
Jacob S.
