Moisture in legend bar.
11b101abn
549
Georgia, United States
To anyone w/ experience:
How do I mitigate the amoute of moistire in my Legend/ I have removed the top covers once to align the TD/AL, then reaplaced them. they were seated propery and the screws are tight to point where they would be over torqued if tightened further. :evil:
Any other placed that would compromise the interior?
The problem is that after one recent heavy rain, I noticed that some of the LED's were glowing and there was water inside the bar. The glow spread to other lightheads and became an issue. I went home shortly after, and when I woke up that afternoon, the bar had dried out and the LED's wre good to go.
What gives? :shock:
MPD 818
1,304
Murfreesboro TN
I have seen very little problem with the federal bars getting moisture in them. You might want to take the top covers back off and make sure all the gaskets and everything are aligned properly.
nbkj58
74
Indiana, USA
There were some issues with the bars getting water in through the bottoms of the older ones. FedSig suggested sealing all holes in the bottom to prevent it.
Sigma Safety
western Canada
Yep - the first year or two had too many holes in the bottom. You can seal all the small holes up and just leave the round black vents un-sealed.
Also, a very common occurrence is people removing the barrel nuts that hold the domes down, and losing the o-rings that live under the head of the barrel nuts. When you remove the barrel nuts - don't lose the o-rings underneath! And make darn sure you don't lose the barrel nuts as they're pricy little guys.
You can also check the seal on the top edge of the 'lenses' (where the top dome contacts the edges of the bottom plastic) and just ensure that seal is all good.
Cheers
M
drew7262
