MX 7000 Arrowstik Question
Derek W
9
USA - NY
I have a MX 7000 with 8 stationary lamps in the rear portion of the lower deck. I was wondering how or if it was possible to wire them to a basic Arrowstik control head. Two of the lamps aren't mounted in this picture.
MtnMan
1,533
Eastern PA
First, make sure the lamps have independent positive and negative connections and are 27W each or less.
Most Arrowstick controllers are negative switched and have five outputs. Connect the positive from each lamp to a common +12V, 20A fused feed. The negatives from the lamps go to the controller outputs. Since there are eight lamps and five outputs, the inner lamps are connected in pairs, as shown:
irishff
522
SW Missouri
Way back in the early days of Code 3 ArrowSticks they were positive switched. This was both the independent arrow stick, and the ones in the Mx7000. They had an 8 lamp controller with individual outputs for each head like pictured below. You may be lucky and find one in someones "junk pile" because they aren't used anymore. The newer arrow sticks have plastick reflectors attached to green circuit boards which separate the ground system from the lightbar itself.
Hope this helps.
Reactions: MtnMan and Pete L.
idk
