MX7000 Problem
Ferbert
15
0
Birmingham, AL
Hey All,
I have a problem. I decided - maybe mistakenly - to do some maintenance on my 7000 today. I took the covers off, unscrewed the deck, and then sprayed some lube on the top and bottom part of each rotator. Well, when I first turned it on after that - the rotators would barely move and the lamps were barely on. After a little bit - nothing worked. My center rotators are still working fine (I didn't lube them). Would the lube be causing a short and them not to work? Any ideas? Let me know, and thanks!
Greg
If you didn't put the screws back in that may be a problem as thats how the rotators are grounded
Might wanna take it back apart and check to see if any of the wires got pinched
Theandymotz
