My Federal Visibar build
Captain4164
952
California
Our UPS driver has an assistant thats been riding a mountain bike pulling a little trailer. They park a trailer in the shopping center behind our house, and the bike guy rides thru the neighborhood delivering packages, the reloads and delivers more.
Well it was quite a sight to see him with the big box on his trailer that contained this:
plybeep68
976
Jonesborough TN
Captain4164 said:
This has been my dream bar for the little time that Ive been doing this, now I have one, so i can stop this obsession!! :bonk:
Nice bar, in decent condition, only bad thing is someone drilled holes in it to mount an antenna bracket on it. :duh:
Good Luck on stopping!! It's an addiction!!
stansdds
3,540
U.S.A., Virginia
Nice! The Series A3 was the last version of the model 11 Twin Beacon Ray. If you check the motor, you may find a decal with the date of manufacture.
djmcfall
47
Filer, Idaho
The old glossy flyer I have for the twin visa beam says "It looks like a RR crossing wig wag light". To get the bar in sync just loosen the slave light platform, then adjust the gear on the chain until the master is 90 degrees from the slave, that way it will wig way in perfect sync. Cool bar, my old PD had red over the driver and blue over the passenger, complete with after-thought alley lights and the wide horn speaker in the middle (I wish we would have had the chrome speakers in the middle)
JennyCop
2,021
Sunny Arizona
Thats ok, no big deal ! Just add an antenna and a Cp25 speaker to add to its coolness and you will be set! The antenna bracket and antenna will just separate it from the rest and in my opinion thats better.
Captain4164
952
California
Thanks, i will sync it!
Reno911
389
Southern Oregon
I like it!!
I would keep the antenna bracket, maybe put an antenna on it if it doesn't have one. It's just something neat that gives the bar character, something it has had since the department it was used with, something only that department had(bracket, position), and it breaks up the norm:D
brianmcfa
208
Nebraska
I'm thrilled that it worked for you. I'm just happy that it got a new home for someone that could use it. I ended up being able to get an Excaliber for use on an in service patrol truck instead of having to try to use this. Win-win!
Captain4164 said:
Bought it from brianmcfa off this site, and he may be sad to know, when it got here, IT WORKED JUST FINE!!! Heres proof:
jph2
2,122
USA Michigan
It does my heart good to hear about these bars being still in service. :)
As for Santa wearing a brown uniform...
stansdds
3,540
U.S.A., Virginia
Yeah, but the letters UPS still stand for United Package Smashers.
Captain4164
952
California
Good deal!! Glad it worked out for both of us, Ive been wanting one since I saw Eric's LAFD Chiefs bar
Captain4164
952
California
Just in a preliminary look today, dont see anything on the motor, unless its underneath, cant see anything from just taking the dome off and looking on the motor.
brianmcfa
208
Nebraska
Apparently it's really easy. When I thought I was going to have to use it, I looked into getting a new blue dome. Thy were about $50 and you could still get new ones. The same dome is used for a Model 14, Model 100, and Model 140 I think.
Captain4164 said:
How hard is it to get red Model 11 domes?? These two will ned to be replaced, looks like they got hot or warm and the tops have a side on each dome that are somewhat smashed down.
Captain4164
952
California
Ok, I was wondering if the 14/100 domes would fit it, I have two clear 14/100 domes coming from ebay, Ill try em when they get here
shues
NW Indiana
Yes, the model 11, model 14, and model 100 all use the very same domes. However, brand new domes from Federal have a frosted top.
Skip Goulet
4,241
Midland, TX
Captain4164 said:
So what antenna would be the appropriate one for this? Here is the bracket.
This looks like a standard 3/4" hole mount, Nick. So any good base-load antenna would work; most likely an old Antenna Specialists antenna was originally on the bar. Nice find. I still have a CP25 speaker with the bar mount on it if you decide to attach a siren.
Captain4164
952
California
Thanks Skip. I have two Cp25s, now I need to decide what two bars I wanna put them on, lol. Ill keep an eye out for a proper antenna for it, thanks
Skip Goulet
4,241
Midland, TX
Sounds good, Nick. So far as the antenna you use is concerned, that will be determined by whatever frequency range you'll be using in Northern CA, if you put a radio in it. If you're using common VHF or UHF, the two suggestions you've had so far will work, but if you're using the 800mhz trunking, that requires a very short antenna, and the mount would be somewhat different.
Skip Goulet
4,241
Midland, TX
Captain4164 said:
Its just for looks, its not going on anything
Should be a winner, then! Whatever you like on it. The Antenna Specialist antennas looked like the same antennas that they marketed for C.B.s in the '60s and '70s.
wfdstation42
584
USA/FL
You can wet sand the speaker with 400 grit wet/dry sandpaper. You can get it at home improvement store. Also the speaker would have been gray from the factory not black.
StormChase85
