need info on horns
jpbaker6
Junior Member
58
1
Bergen County NJ
hey everyone,
dont really have any idea about horns/sirens but was looking to get one that is one noise not like a police siren. is it possible to hook it up and use as my regular horn?
thanks
john
basically you have 2 options, a whelen pap112 which requires a seperate speaker and will run about $300 or so or you have the pricer option of grover air horns.. i did not see any affliation with pd or fd in your profile so if you are not i would not go with neither option..
otherwise both can be wired into the vehicles horn ring or set up on a seperate switch so you have the function of the factory horn and air horn with a flip of a switch.
other misc. option is a train horn
there are more than just those three options.
Dixie horns, la cucaracha, the ol timey ooooooooooooooga horns, etc. just go to jcwhitney.com and type in horns. :lol:
or some auto parts stores carry after market horns.
Carson sells an amp that does just horn tones. You can choose between 2 different tones and it comes with a controller, too.
like Jarred said there is numerous other options out there,what i listed is a couple of the popular options,there is multiple novelty horns
Carson has a horn-only box that you can get with a speaker for around $150. $200 if you want the waterproof module. Probably the cheapest route, although not the loudest. You can buy the components separately and get a better speaker but real air horns are louder. And much more expensive if you go for a Grover 1510 horn (the fire truck horns) because you'll also need a compressor and solenoid/valve. This is all assuming this is for a volunteer fire/ambulance service... if you just want a loud horn for your car, there are tons of air horn kits on ebay for cheap. Wolo makes several. The Hella Supertone electric horns are very loud, too.
Go green. Tie a goose to the fender and put a pull cord through the side window, tied to the tail.
if you'd like a "natural" Q sirent.
connect cat to vehicle and tie string aound testicles and then pull string as stated above.
it will have a quick wind up, and a "stutterted" top out tone with fast wind down and growl at end.
the hissing noise could be from the cat or where the cat slashed your tires.
is this a decent unit? Whelen WSSC 30 Watt Siren/Speaker
yes I am emt and if i have time will be joining the vol fire, i see that it has a air horn function and its cheap and all contained with my choosing of switches. the carson item is $200 and i found this for $140
It's fine if you don't need any vehicles to hear you, only pedestrians or people on bicycles. It's a 30W siren, so it's actually intended for ATVs and other small vehicles where the low power isn't a problem. Even the 100W air horns aren't *that* loud for punching through all of the sound deadening insulation of cars, so with this siren you could be right behind somebody at a redlight and if their stereo was on, they wouldn't hear you.
If you're looking for spend about $200, you can get 400 watts of airhorn from this Dual Omega 90 setup (I am not the seller): viewtopic.php?f=20&t=4247
You could probably sell the control head and CA92 cable for a decent sum, and just run a wire from any momentary switch to each of the amplifiers.
What he said. :D :D
Jaskod
