Old, but still in Service O.O
Wolfie
287
Arrey, NM
I was at a Wildfire Fighting class at my Fire Dept today. Other departments were invited, and some came from Monticello-Placitas Volunteer Fire Dept. I thought we were running some pretty old rigs, but their firefighters showed up in the beauty pictured below. I would call that a Federal Twinsonic on there, wouldn't you? Yes, this vehicle is still in service. :)
ryan
2,996
Massillon, Ohio
Diets omnichief or cheetah bar. Def. it a twin. I know a guy whose really into twins and he said nope.
CrownVic97
Hazen, ND
Reactions: OliverD
Wolfie
287
Arrey, NM
Whatever it is, I like it. That truck has to be 40 years old too, I am guessing. I am not really a chevy guy though.
801
679
NV
the pickup is a 68 to 71 Chev based on the grill. And its great that they keep a period correct lightbar on the truck. Definitely a Sireno Condor. Sweet old truck, but I know there are grants out there for a newer vehicle, I just got one for our County Dept.
Wolfie
287
Arrey, NM
If it ain't broke, why fix it? That may very well be the original bar put on that truck when both were new. Did anyone catch that siren on the fender? :D
Reactions: CrownVic97
jph2
2,122
USA Michigan
The bar, the siren, and the truck are just really cool! It's a blast from the past and it's great to see it still in service and looking really good. That says a lot about that department right there.
MRFD715
31
Iowa
We still have this in front line service. Not period correct lighting on it though.
1975 Dodge/Pierce W-300 Mini-Pumper
JazzDad
5,165
USA
That bumper looks like a toy car I had as a kid. You'd roll it into the wall, and it would pop into 5 pieces.
cmb56
746
Norrköping, Sweden
As other members have suggested it is a Sireno Condor.
It is easy to spot.
More or less straight sided lenses in comparation with the TwinSonic that have slightly sloped sides.
The lenses are higher than on the TwinSonic.
Independent rotators in black plastic that rotate in the same direction in comparation to the TwinSonic that has synchronized rotators in metal that counter rotate.
Both lightbars has similar stepped mirrors that make them look similar in flash effect except that the Condor is independant and do not have the inboard to outboard flash effect because of the rotation in the same direction.
All this was probably because of the Federal patent of the TwinSonic.
Sireno could most probably change the polarity of the motor to have the lightbar counter rotate at a later date when the TwinSonic patent had run out.
I have never seen that but I have a four sealed beam Sireno beacon that have insulators on the motor so the polarity is changed on the motor that makes the light rotate in the opposit direction than original.
It looks factory installed and not home made so I think it might have been a possibility from Sireno if ordered.
Michael
coop359
495
USA Tennessee
Doyle's old engine looks like a FS model 16 beacon. A tow company in the 70s had the Sireno Condor with front cascade mirrors and rear PAR 46 alternating sealed beams with Amber domes. Very bright
CrownVic97
Hazen, ND
The one thing that these Sireno Condors and later TwinSonics had in common was that the same Type 3 motor used in AeroDynics, JetSonics, and TwinSonics was also used with Sireno's independent rotator modules. That's about it for similarities of the two companies.
Doyle257
658
Cheektowaga, NY
It is a FS beacon...but along the last 40 years or so, some genius stripped the original internals out, and replaced them with a teardrop base and rotator. Still irritated by that.
Also, on the officer side, there is a Sterling Sirenlite model 30. Glass lens is cracked, in case anyone has a line on a replacement...
JFRD10925
30
Jacksonville, FL
Pumper
What make/model are the "A" post double-side spotlights. Had these on Modulance Ambulance Corp. (Grand Prarie,TX) in '75.
MRFD715
31
Iowa
We were actually approved to replace that truck about a month after I posted that so we don't have it anymore. I'm not sure what make those spotlights were but they didn't work very well.
Wolfie
287
Arrey, NM
Instead of starting a new thread, I'll just add on here. I took this old girl out for a spin today. 1980 Ford F700. 496cid gas, 5sp trans, 2sp rear-end. I am not good with Whelen models, but it's a Whelen strobe bar on the roof. The red/blue wig-wags on the front bumper look identical to the ones on the truck I started this thread with. (Same station.) There are a pair of par 36s in red on the back that flash simultaneously. I am gonna have to get in there and either wig-wag them or put in a second flasher so the rear can be more attention getting. Some of the wiring for the roof bar got damaged so I am gonna have to go in and fix it too. Still, while she may be old and tired, she is still in service. None of the in-service trucks I post are parade only or anything like that. They are all subject to dispatch 24/7.
Reactions: jph2 and Tony P
Wolfie
287
Arrey, NM
I guess I should mention that, since the original thread started, I have joined this department. I am still with the other one...just doing both now.
Jun 18, 2013
3,718
PA
I was just over in NJ this weekend near Netcong/Budd Lake.. one of the local VFD units still runs a 1978 GMC 6500(?) It's still Active 24/7. Apparently it had a 184 Powerlight on it until just recently and they just did an LED upgrade package to it.. so no it's not going out of service anytime soon!
woobatu
