C2Installs
Hang on to your hats...
This is the PFFD Chief's new 2013 Expedition. He wanted Whelen, so he got Whelen...and then some. Chief came to me with a concept and a wish list. I worked it over and removed some items while adding others for more utility and effect. He originally wanted a CenCom Sapphire, but I was able to sell him on CANTrol once he looked over my article on the system that was in Police Fleet Manager last summer. The overall inspiration for my build was the Expedition Whelen displayed at FDIC, which Hugh A. provided pics of.
So, here's the list:
Whelen:
1x Par46 spot/warn bulb for spotlight
1x Split Inner-Edge LINZ6, all red in windshield
2x Wide angle IONs - Upper Grille
2x Par36 warn/drive interweaved fog light replacements - Lower front fascia
2x LinZ6 r/w split recess mounted in lower corner fascia (this was a trick, but looks awesome)
2x VLED led combo warn/spot/puddles on upper front quarter panels (mounted with 18* spacers)
2x Wide angle IONs - Mirror fronts
2x Standard ION - Rear doors
2x Standard ION - Rear windows
2x Vertex - Brake light housings
2x LinZ6 - with TIR3 narrow flanges and Vertical LP bracket (would go with horizontal if doing over...spread is terrible)
1x Howler Siren w/ dual speakers
1x SA315 Speaker
1x CANTrol system with "CenCom" remote head
1x CANTrol remote 16 WeCan module
SoundOff Signal:
2x 10" flush mount LED strip lights - recess mounted in rear hatch panel
2x 6"x3" interior LED dome light - mounted in rear cargo area headliner recesses
2x Mity Nite lights - rear bumper for reverse and scene lighting
1x Universal dual color LED dome light, r/w
1x Select-a-pattern solid state headlight flasher
Feniex:
Cobra 800 r/a light stick - rear hatch upper glass
TITAN 600 worklight - front lower grille
Other:
Unity post mount spotlight
Havis console
Havis laptop docking station
3-hole DC outlet box
SL20X flashlight and charger
2x Kenwood radios (NX800, TK8180)
1x Motorola 700 band radio with speaker
3x low profile "can" antennas for appropriate bands
So the install took a bit of time and was done in three phases based on when items arrived. Feniex took the longest, Whelen stuff was here in two days. Final phase just finished tonight and involved Feniex install, spotlight install, and CANTrol modifications. This truck is cool.
So my concept was to have a very well lit vehicle that could move through Pigeon Forges notoriously heavy traffic, which is filled with very distracted tourist drivers and stubborn local drivers. Because he wanted a slick-top, I had to make sure lighting was adequate from all angles and multiple levels. I wanted to have 100% on time from any angle but still have enough "movement" to be eye catching. Lights were placed to be no more than four feet apart on the truck's perimeter (without regard to height). White light was only used at front forward of the mirror, with the VLED spots, Par46 spot/warn, LinZ6 splits, Par36 driving lights, and TITAN work light augmenting the headlight flasher. The LinZ6 splits are also working as a surrogate HAW as I did not want to mess with trying to put LEDs in the headlight housings. They work terrific and are an excellent and much more effective solution, IMO. Great output with excellent spread...no split fail there.
The CANTrol system was the second I've worked with and the first I installed on my own. It took some time and lots of phone-a-friends to get the programming worked out. I still have some glitches to sort through, but all are from my lack of experience. The system does what you tell it to. The inputs I wired were horn ring, park sense, headlight sense, brake sense, marker light sense, fog lights, reverse lights, and ignition. I have the system fairly complex with different inputs resulting in different lighting functions. I have not quite got everything working the way I planned, but will with a bit more tweaking.
The Whelen stuff was pretty simple to install, no real tricks here, just used good mounting brackets and selected lights specifically for each location. Fabrication was minimized. No surprises with making it all work, either. I have a Whelen scan-lock programmer that made setting all the lights to steady burn quick and easy. Wiring the CANTrol is not hard, but it can take a bit of time to run all the circuits. The Remote 16 unit made it easier...all front lighting is powered by it and it connects to the master CANTrol with a two-wire communications cable.
The Feniex products are ok. They were a compromise to save a little and keep the job in budget. I really didn't think a rear stick was needed and didn't want to drop $700 into a LinZ6 Dominator. If I was doing it over, I would kick the Cobra 800 to the curb and use a TIR3 D8 instead to save money over the LinZ6 D8. I expected the Cobra to work better through the factory tint given the rave reviews and tir-like optics. It's just ok. It did mount cleanly (had to make brackets, though, it comes with none) and was easy to wire. The patterns are so so. I guess I just wish I had kept the lighting all Whelen. Customer is happy, and the Cobra works. It's interior mounted, so hopefully it will be reliable.
The TITAN 600 is also ok. It is fairly bright and was inexpensive. It, too, lacked brackets. What I don;t like is that the lightheads are all somewhat different colors, some more blue or yellow than white, some white, one a bit purple. It's subtle, but still noticeable. The TITAN was chosen because it is very thin and fit the lower grille opening yet still left decent airflow. Original idea was to install a push bumper and mount Micro pioneers to it. Obviously, the TITAN solution is much less expensive. Plus, a little bird told me to pick Howler or push bumper, due to both items using the same frame mounting points. If I had to do it again, I might still use the TITAN. Why is it that Whelen or SOS don't have a similar product?
The VLEDs are killer. They look good on the fender, are amazingly bright given that the LED panels are very small, and visible from all angles. Just wow. The spot light (alley light) is great, and the CANTrol system allow it to be counter-flashed with the red. It hammers intersections at side angles. The puddle light is neat, but certainly not necessary. I'm not really sure it's useful. I tied it to the factory mirror-mounted step light on each side.
The IONS are bright. Really bright. Mounting is pretty good if using the screw/glue bracket, but the clamp bracket is not all that great and distorts easily when tightening. The pedestal mounts were used in the grille and they are very nice. Unfortunately, they are pretty expensive.
The rest of the install was pretty basic. The SOS interior lights are a great value and look sharp. The rear cargo area lights up like an operating room. Really. It's wired to a separate switch because it is really overkill for general use. Perfect for digging for gear or setting up a command post. The SUV may get a pull-out tray and command center down the road, but not this budget.
Anyway, I'll post more as i go. In the meantime, here are some crappy night videos I just shot tonight and I will get pics and day vids tomorrow. I know, I know...Illumi-fail.
Mode 1: Mid and lower level perimeter lighting only, red only, set to Steady-Flash (the MA state police pattern. It's excellent for on-scene use, but video doesn't capture it well)
Thanks for looking and check back for pics and day vids.
A few pics:
[Broken External Image]:[URL]http://i499.photobucket.com/albums/rr351/C2Installs/IMG_3521_zps42d7aaaa.jpg[/URL]
[Broken External Image]:[URL]http://i499.photobucket.com/albums/rr351/C2Installs/IMG_3517_zps552648bc.jpg[/URL]
[Broken External Image]:[URL]http://i499.photobucket.com/albums/rr351/C2Installs/IMG_3516_zps2286fe9b.jpg[/URL]
[Broken External Image]:[URL]http://i499.photobucket.com/albums/rr351/C2Installs/IMG_3513_zps55ce8ebd.jpg[/URL]
[Broken External Image]:[URL]http://i499.photobucket.com/albums/rr351/C2Installs/IMG_3527_zps62d3163c.jpg[/URL]
[Broken External Image]:[URL]http://i499.photobucket.com/albums/rr351/C2Installs/IMG_3529_zps4908d29d.jpg[/URL]
[Broken External Image]:[URL]http://i499.photobucket.com/albums/rr351/C2Installs/IMG_3511_zpsa175cfd2.jpg[/URL]
[Broken External Image]:[URL]http://i499.photobucket.com/albums/rr351/C2Installs/IMG_3475_zps6494abcd.jpg[/URL]
[Broken External Image]:[URL]http://i499.photobucket.com/albums/rr351/C2Installs/IMG_3491_zps7fdab886.jpg[/URL]
[Broken External Image]:[URL]http://i499.photobucket.com/albums/rr351/C2Installs/IMG_3492_zpsdc3ebaf0.jpg[/URL]
[Broken External Image]:[URL]http://i499.photobucket.com/albums/rr351/C2Installs/IMG_3496_zps6c62f0f2.jpg[/URL]
[Broken External Image]:[URL]http://i499.photobucket.com/albums/rr351/C2Installs/IMG_3502_zps81c62890.jpg[/URL]
Whelen:
1x SA315 Speaker
SoundOff Signal:
Feniex:
Other:
Havis console
A few pics:
