project CTS bar
801
679
NV
I've had this bar on my shelf waiting for me to start to tear into it. I got it a while back from a member on here and it needs quite a bit of work. It appears to be a early series CTS with the square sided motor. The motor runs smooth and quiet, I got bulbs that work, I had to get a couple of them off Amazon.
A couple of questions, how to get the chrome strip off the front? It arrived damaged and the member shipped me a new one in great condition.
The center tray has a stripped screw, what's the best way to remove it? I've soaked it in penetrating oil, and it's not going anywhere.
What's the best way to repair a dome with a crack down the full length of one of the corners?
Here is a link to the photos:
http://imgur.com/DdRMHYx (end caps)
http://imgur.com/wuK6wPK ( drivers side before I removed the flasher/rotator)
http://imgur.com/wXcYRzQ (speaker tray with stripped screw on right side top)
http://imgur.com/JowatRl (pass side with mirror, the motor was removed when I got it)
ERIC6913
3,621
California
The chrome strips can be carefully pounded off with a standard screw driver and hammer. I can't give you any tips for the screw, because if i have a stripped screws i take my frame to a machine shop for removal. The best method for the dome is too find another good one lol.
Jun 18, 2013
3,718
PA
depending on the crack you might be able to stabilize it and stop if from growing further using silicone caulk.. Same type used on the aero dome segments. Wont be perfect but I don't toss domes because of hairline crack. let alone CTS domes.
just saying.
Rob
801
679
NV
just saying.
Rob
The dome with the crack is a CTS dome with the amber insert. I am going to save it, because you can't just order a new one up from FedSig. The crack is in the front driver's side corner running vertically in the corner.
nerdly_dood
2,312
Georgia
You can upload them to www.imgur.com without an account and link them from there using thsee tags:
Code:
[img] (insert URL here) [/img]
Reactions: 801 and Tony P
801
679
NV
I took the assembly for the rear flasher and front steady off the frame, I found both positive wires were crimped together after the flasher, so both lights flash??? It appears to be factory.
http://imgur.com/Kjej5NW
Reactions: Tony P
Jun 18, 2013
3,718
PA
I'm trying to remember how the wiring block on my CTS bar was.
The flashing amber has a separate lead. I believe the front facing par 46 was wired into the main power lead. If both are flashing something is most definitely wired wrong. the tung sol flasher should only be connected to the rear lamp.
Skulldigger
1,740
Georgia / USA
The tag is for a motor. You can get a screw removal kit at Sears that will easily remove a broken screw. I have one I use all the time.
Reactions: 801
801
679
NV
On my San Diego FD CTS the flashing amber, front par 46 and rotators/motor were all on the same lug.
Many decades ago, when I drove a Diplomat with a red/blue CTS, the Unitrol was wired for Position 1, rear amber, Position 2, 1+ CA red, Position 3 1+2, rotators and HLF. The shop must have changed the wiring on the wiring block. At that time I didn't pay any attention to how it was wired, just changed a bulb if needed and went back to work.
Reactions: denko3
Crownfire
531
USA CA
LE agencies often wired the steady red separate from the rotators. Saw many traffic stops with just the rear amber and forward red lit.
801
679
NV
Back in the day, I was told by my FTO to keep the front red on during the stop until the person was free to leave. When I became a FTO I passed that along to my trainees.
woobatu
