Push Bumper LED ( Side Warning ) Suggestions needed for 2011 CVPI .
TX-LEO
139
San Antonio
I'm going to install my own white LEDs on a city vehicle for side/intersection warning as this was deemed not important.
I have been out of the loop as far as LEDs and equipment for a while now.
Are there any bolt-on items that anyone has used that will fit this idea that someone can suggest? The LEDs will be installed on a standard push-bumper ( sides of course ) on a 2011 CVPI.
A quick search revealed Whelen has 46' LINZ6 brackets, but not sure I want that type of angle and was thinking of simply mounting a linz6 to the side for 90 degree angle.
Any suggestions appreciated.
FreshDave04
3,000
Elkhart, IN
Lt. Dino said:
I had Tomar RECT13's on my Charger (I know the OP said CVPI) for intersection lights. It's more of a TIR optic but they worked quite well.
Yep! The Rect13 and 14 series is great, as well. They can screw right on to the push bumper frame. They're potted and hermetically sealed, as well as come with a 5yr warranty. I'm a Tomar distributor, so if you're interested, shoot me a PM!
Pimp
1,872
Louisiana
fireman616wfd
2,126
Oxford, MS
TX-LEO said:
All good suggestions provided. I was also thinking of putting a couple of my own TIR3s on the sides that I Took off my old goldwing.
well just do that then... I would put alot on the side of a PB because it is easy to put too much there and doesnt look good. Another option if your wanting something a little larger than the TIR3s and maybe dual color or split is the Sound Off Ghost flush mounts.
TX-LEO
139
San Antonio
I wanted something with a bit more punch than the TIR3 style, even though a few of the ones I have are linear.
I didnt know those ghosts were available in flushmount too now. That a good idea. I will have to keep my eye out for some used ones.
HILO
2,781
Grand Prairie Texas
Whatever you end up with, your on the right track with the clear. That is the best color for intersection attention. With it being Texas, you could do a split clear/red on either side. Are you going to put HAW LED's in the marker lights? If so, go clear with both and sync them to alternate. that would be some good intersection lighting!
TX-LEO
139
San Antonio
There are corner mounted LEDs in there yes. Thats a good idea. I'm not sure what brand they are, but it should be easy enough to pair them up.
On the mount holes, drill a pilot hole then use nut/bolt type system? I doubt a sheet metal screw is going to be strong enough for a pushbumper.
ETA: as you can see there are holes, but very unlikely they will match up to what I buy.
[Broken External Image]:http://i219.photobucket.com/albums/cc55/tx-one/BUMPER.jpg.
fireman616wfd
2,126
Oxford, MS
FLUSH MOUNT GHOST:
[Broken External Image]:http://soundoffinc.com/warnamber/surfacemnt/GHOST_Single/EGHST2(x)_01.jpg
NEW RECESSED MOUNT GHOST:
asoundoff.smugmug.com_LED_Warning_Lighting_Surface_Mount_Lightde02c41a082d4ef68c4ce33a627b5bcb.jpg
GHOST ROCK:
[Broken External Image]:http://soundoffinc.com/white_illum/SpotLts/GHOST-Rock/GHOST_RockLt_up.jpg
and.... THE ORIGINAL GHOST:
asoundoff.smugmug.com_LED_Warning_Lighting_Dash_Deck_Grill_Ligd0b276e1442d2a67b85ab4c9ced62799.jpg
I think thats all now... haha
Jan 6, 2011
94
Texas
I have some Federal Signal Impaxx in white and 45 degree brackets also, NIB. These come with a bezel & gasket & can be surface mounted also.
I'll make a fellow Texan a deal, & fast shipping !
TX-LEO
139
San Antonio
Thanks for the offer. I'm going to have to wait a few months before I do this as I have a few trips planned. Cash for stuff like this is scarce and I'll likely be doing it sometime after September. Will keep your suggestion in mind though.
VolEms
2,112
NY, USA
I would put Tomar Rect25 High Power. If you have the money I would use a light with a bigger footprint. You have a lot to choose from. You can also mount two smaller lights side by side like my freinds install. Look at the interesection warning. He also put a Vertex surface mount a little further back. Enjoy the vid.
RL1
1,650
Ga
I love that car!
tdi419
