renovation Code 3 SD (sealed beams)
toon80
2,489
Laval, Canada
Whoa!! Ça, mon chum, ça, c'est du beau boulot!!
-aka-
Whoa!! That, my friend, that is of hell of a job!! :D
How did you cleaned the metal inside?
CrownVic97
Hazen, ND
Jeez, that's really good work there, man!
ryan
2,996
Massillon, Ohio
Eric, you know your impressed with this! I am amazed at your process!!!!
wfdstation42
584
USA/FL
Great job!! What brand mechanical siren was in there? I know it's not a standard option but are you going to put it back in it?
dmathieu
May 20, 2010
8,784
S.W. New Hampshire, USA
The siren is a Universal Security siren. They were used for car alarms in the 1960s. Probably not original equipment with the lightbar.
Dan
fireball3
864
Lyon, France
Thank you very much for your comments!
Cleaning the Inside
a lot of time sanding with sandpaper (P1000) and then polishing with "Belgom" Alu or Chrome, on all parts.
cleaning brass parts with "Miror"
sanding and polishing with machine and hand finishing.
cleaning of areas difficult to access with cotton swabs to the ears! :))
a lot of patience!
When disassembling the screw shaft driver "+" to the rotor bulbs broke!
In France, very hard to find fasteners U.S.! :-((
Dan
correct!, Dan
The mechanical siren was delivered to me with the lightbar, mark "universal" model SA-8M; Yes, I'll put it in because it's still vintage and I have no other siren.
thank you again for your compliments, but the job is not finished! :)
May 25, 2010
140
Hamburg (Germany)
fireball3 said:
- how to know the wattage, the sealed beam bulbs?, it is not mentioned on the bulb!
Nothing at all on the bulbs?
You can use a amperemeter/multimeter to measure the amp draw of the bulbs. Then multiply that value with 12 (Volts) (or 13.8, if you are using a powersupply) and you get the wattage of the bulb.
drb
108
Southern California
fireball3 said:
Pics added! ^^
questions for the experts!:
- Can I install domes Twinsonic on my Code 3 SD?
thanks
GE 7400 (35 watts) was standard on the SD and XL bars from the factory. I purchase all of mine from Ryder Fleet Products:
Ryder
CFD125
Carver, Mass.
Beautiful restoration.
Inspires me to do the same with one that I was only going to clean up. Now I just may have to completely restore it.
StormChase85
