I had a Sound Off S.S. Flashback (older) that I installed into my 2004 Ford Explorer. I no longer had the instructions. I was told the wires go as follows:
Green- ground
Brown- switch
White- positive (battery)
Drivers side (brake)
Pink-car
Yellow- bulb
Passenger side
Orange- car
Blue- bulb
Solid red- reverse light
I installed the flasher and the lights flashed properly (reverse/brake lights alternate). When I drove my truck the right directional flashed fast like a bulb was out. The right rear brake/turn signal was not working. I thought that it was just out by chance. I replaced the bulb and it still does not work. I did reconnect the wire back together on the right side and it still did not work. Any ideas what the problem could be?
Thanks
Eric
Green- ground
Brown- switch
Pink-car
Yellow- bulb
Passenger side
Orange- car
Blue- bulb
Thanks
Eric
