Skulldigger
Siren Volume limiter !
Read this ad in your best Billy Mays voice:
Well after some trial and error, experimentation and a little expense I finally figured out the simplest and least expensive way to control the volume of a siren. If you are like me you have electronic sirens inside on display but you can't play them because of the wife, dog, neighbors and your audiologist. Well I found the cure! This simple Siren volume Limiter reduces the volume of your siren speaker to a comfortable level for display and showing off. Tested on 58 Watt (Interceptor) and 100 Watt (Whelen 295HF100) sirens with no problems. Single Speaker each. Safe, can not damage your equipment. Money back guarantee. You will be the envy of all other collectors who have those fancy sirens but can't listen to them ! Plugs directly to siren positive output or put inline to the positive wire to the speaker. Comes with connectors.
I currently have 5 available.
List Date: 3/31/2017
For more info, click here to view the original listing: Siren Volume limiter !
SOLD
SOLD
