Switchbox Question
Better than Velcro is 3M Dual Lock. Make sure to thoroughly clean both surfaces before attaching the adhesive side of the Dual Lock. I usually use glass cleaner, dry the surface completely, then use rubbing alcohol, then dry the surface completely once again.
Any place to get the stuff? i am sure an online search will help but if you regularly use it then i might as you where you get it from. Thanks!
I use this stuff after I clean the surface:
[Broken External Image]:http://hhrboutique.com/images/flexchrome/06396.jpg
3M 06396 Automotive Adhesion Promoter, Sponge Applicator Packet - 2.5 cc
You'd be amazed at how well this stuff works! It's expensive, but it's better than having officers coming in every other day complaining about stuff falling off or detaching.
go toy uor local radio shack if you have one and by the super lock or something to that effectmit is the same 3m dual lock in a rebranded package and it is cheaper,you get 4 4x1 parts for about $3.50,it is strong enough that it holds the 4 head dominator to my windshield
scrapinlow
