Talon Sync Question
Whelen ULF44 led flasher. It will sync with the dominator and you can set your talons to steady burn and attach them to the flasher. Thats what I did and LOVE it. :D
You can sync any 8 Whelen lightheads together, no matter what the model is, as long as it has a sync wire. remember though, only certain patterns sync.
If they are the sync models, simply connect the gray wires.
If they are not the sync models, simple set them to steady burn and use a flasher, i.e. a Whelen flasher that would have a gray sync wire to sync to the D4.
As stated, as long as they are SYNC models just connect the gray wires together and make sure they are all on the same syncable pattern. and yes the d4 has a sync wire so just connect that as well. better late then never....good luck
Technially, I would just say 'sync' wire. The sync wire on a Vertex is green, and a ULF44... well, that's whatever color wire you use. :D
In 'this' situation, the sync wires are grey.
Thinking of trying this myself. You got any video of what it looks like?
Jmann639
