This is going to be fun
Jun 18, 2013
3,718
PA
I may have a red dome or 2 still leftover if your looking.
stansdds
3,538
U.S.A., Virginia
Those were effective lightbars, but with the penalty of a high amperage draw. Other than the broken lens, yours appears to be in very good condition. If you check the motors closely, you may still be able to read a date, this date would be within a month or two of the actual manufacturing date for your PSE Code 3 SD bar.
Elmira, ny
Whats ironic is only 3 bulbs were the GE7400, the rest were 4464,4416 and a 4411. The ironic part is i have an nypd aerodynic that needed bulbs, so the 4416s and temporarily the 4464 is now in my aerodynic.
now to find the remaining 7400 bulbs (crying yay lol)
Reactions: stansdds and Dave F
stansdds
3,538
U.S.A., Virginia
You may spend as much on replacement bulbs as you did for the entire bar.
stansdds
3,538
U.S.A., Virginia
thats what im afraid of.......but even if i find used bulbs i’d be okay with it, all its gonna do is sit on a shelf anyways
You can knock off 3 amps by simply using 4416 bulbs (30 watts) as opposed to 7400 bulbs (35 watts). 4416's are still commonly available.
CrownVic97
Hazen, ND
Wailer
2,293
Canada
Where I live, that used to be the standard ambulance light bar colour combination. Red on the driver's side and clear on the passenger's side.
Reactions: EHFD_Tower_751
stansdds
3,538
U.S.A., Virginia
Here in Virginia, when clear was first approved for Fire and EMS vehicles, Twinsonics would be set up with a clear lens on the driver's side, one clear and one red bulb, red lens on the passenger side. All-light PSE Force4 XL and LP's usually had red outer lenses and clear center section.
Elmira, ny
Ironically on the ear side it was setup up as red/clear (red clear on one rotator and then the same on the other rotator)
Elmira, ny
Interesting.......elmira fd had a pumper with the force 4 version of bar with red on drivers side and the clear on captain side
jriccio@necommunications.
